Thread: Just filled new pool, yellowish green water
    Jun 2012
    Swisher Iowa
    15
    New pool, new property, new well and avoiding the overly opinionated neighbors assistance and the local pool store , I've read all these posts, my head is spinning, but I am not wanting to fail at this. Any tips, well water filled, half bypassed on softner / carbon filters other half filled thru whole house system /green murky water and Crazy test levels? Pool has been filled full for 8 hours I've added 32oz of HTH metal and stain remover, and roughly a quart or algicide , filter/pump is running, heavy rusty oily residue bubbling in skimmer basket , babysitting it and cleaning out hourly, new find as of 11pm, pump is near worthless, upgrading sooner than predicted, Paper towel layed in skimmer basket is catching a lot of metal residue (I assume ??)
    How to / when to / shock ? Wanting to go with BBB supplies ,
    Taking current water sample into town in the am
    Help -- don't want to do to much to soon or to little to late !!
    22x52 pro series steel frame new 2013 /10.5k / Intex Sand filter (new) 3000gph /1hp /well water/ tf100 kit w BBB method
    Re: Just filled new pool, yellowish green water
    That is most likely caused by iron in the water, fairly common with well water. Sequestrant should clear it up.
    Jun 2012
    Swisher Iowa
    15
    I let the pump run all night , had a paper towel covering the skimmer basket, it was dark red brown this morning,
    Test results
    FC 1
    Ph 8
    TA 290
    CH 330
    Planning on shocking it this morning, want to get my FC up and see where that goes?
    Any helpful tips please :/
    If possible, before shocking, lower your PH to 7.2.
    Jun 2012
    Swisher Iowa
    15
    Update,
    1. Need to get a better test kit , asap
    2. Test results from pool co
    FC 0
    TCI .54
    PH 7.5
    CH ( they dont test for?)
    TA 113
    CYA 0 ! Yeah!
    There recommendations
    3gal of shock
    Start chlor tabs
    3oz of algicide
