Thread: Add Salt light on during Super Chlorinate
    Jun 2012
    Barrie, Ontario, Canada
    28
    Hi there.
    I pressed the super chlorinate button on my zodiac lw2-24 and the add salt light came on immediately and is still on (10 mins after turning on super chlorinate).
    Is this normal? The reading of salt is 4000ppm but the FC is 0.1. All 5 lights are on on the display output though.
    Thanks
    Size - 50,000 Litres / 13,208 g (32' x 16' x 4.5' Sport Pool)
    Filter - Jandy CL460 Cartridge Filter
    Salt Water - Zodiak LM2
    Pump - Jacuzzi Magnum Force
    Heater - Laars LT LT250NS-C
    IG Pool (Vinyl)
    2003-2005 ish
    Re: Add Salt light on during Super Chlorinate
    You should add chlorine manually when shocking the pool. Proper shocking requires bringing up the FC level quickly, something a SWG is not designed to do.
    Jun 2012
    28
    The pool has been shocked already. I'm trying to use the swg to add chlorine to the pool. Will that ruin the swg?
    IG Pool (Vinyl)
    2003-2005 ish
    If you are done shocking then my comment does not apply. On the other hand if FC is 0.1, I can't see how you could be done with shocking.
    Sorry, I am not familiar with their light patterns, so I can't answer your main question.
    Jun 2012
    28
    I've heard that bleach works well. Do you recommend I do that?
    IG Pool (Vinyl)
    2003-2005 ish
    Jun 2011
    Nj
    57
    i use bleach when i shock with my swg
    i never use the super chlorinate feature on it, dont want to wear it out
    what percentage is it set to and how long is it running for?
    11,000 gal inground fiberglass pool
    Aquarite SWG system
