Thread: install hose bib in pool plumbinb
    Spiccolli's Avatar
    May 2012
    Gold Canyon, AZ
    63
    I got my slide installed an we currently hook it up to the garden hose from the house. I'd like to install a hose bib in my pool plumbing so we can keep house pressure for the misting system and also so that we are using pool water on the slide.
    I'm thinking that it should go in-line with the return, before going into the ground, but want to make sure that this does not mess up the hydrological dynamic of the plumbing. Any adverse effects?
    I think I would have to cut a few inches out of the return line, use 4 elbows, some pipe pieces, and some kind of part that has a bib on it already. Does this sound right?
    Is there an easier way?
    1992 15X30 14000 Gal IG plaster, Pentair 011018 - Intelliflo VS Pump with Timer, 350 lb Sta-rite hrpb30 sand (yeah, the 32-bolt clamshell)
    38,524
    Re: install hose bib in pool plumbinb
    Any place on the return can be fine. Many pool builders put one between the pump and filter (for draining, or something) ... but then the water is not filtered as you may like for the slide.
    All you need is to be able to get a T somewhere in the pipe. Then there is a "cap/plug" that fits into the fitting with a threaded hole to screw in a bib. If you have enough movement on the pipes, you may be able to just put the T in-line ... that would have virtually no affect on the flow.
