Thread: cya
    cya
    I have been skimming the last pages of forum questions to see if this topic was covered(thank you moderators who keep answering all the questions we newbies have!). I started the season with high CYA levels then the levels dropped as we had 5 to 6 inches of rain. I did shock the pool which probably took 6 to 7 days to complete and all has been well but I notice my cya levels seem to be creeping up. how is this possible? Admittedly, the test is not intensely accurate because you are "eyeballing" when the dot disappears, but I don't think I would be that inaccurate. Does cya occur in nature at all. i was at 50 and now it looks to be closer to 65. I repeated the test to be sure. At the start of the season I was using pucks but haven't since May. thanks!
    17x33 inground vinyl pool, 22,000 gallons, 1 1/2 hp hayward pump, Hayward systemII DE filter with chlorinator, north central pennsylvania, heater
    Aug 2010
    Dallas, TX
    4,052
    Re: cya
    No, it can't creep up on its own.
    Re: cya
    What are you using to add chlorine to the pool? Several forms of chlorine contain CYA.
    38,235
    Re: cya
    Also the test is only good to about +/-10 and the lighting has a large affect on the test results. See:
    extended-test-kit-directions-t25081.html#p206397
    Re: cya
    I have been using Walmart and dollar store bleach(Tundra). the ingredients say 6% sodium hypochlorite and 94% inert ingredients. could that contain any stailizers? And I sure wouldn't swear I am doing the test 100% the same each time and yes I have already read the extended directions. I try to use the same light but the light can be variable.
    38,235
    Re: cya
    Quote Originally Posted by mdreese
    I have been using Walmart and dollar store bleach(Tundra). the ingredients say 6% sodium hypochlorite and 94% inert ingredients. could that contain any stabilizers?
    No ... it is water, salt, and small amount of lye
