Results 1 to 7 of 7
Thread: Should a SWG Pool Taste Salty?
    Jul 2011
    Broken Arrow, OK (Tulsa)
    294
    I will have to check the salt level with test strips today or tomorrow, but I'm pretty sure my level isn't sky high, since I've not added any salt since our PB put it in back in March. One comment everyone who's been in our pool has is that all can taste the salt.
    Is this pretty normal, or is it something I need to look at?
    16 x 31, Approx. 12,000 Gal Freeform IG pool; Flagstone coping; Quartzscapes Super Blue plaster finish; Tanning ledge w/2 bubblers; 1 HP Pentair Whisperflo pump, Pentair sand filter; (2) Pentair Intellibrite LEDs w/controller; Easytouch8 w/IC-40 SWG; Salt finish concrete decking.
    GreatCanadian's Avatar
    Jul 2011
    St. John's, Newfoundland
    844
    Re: Should a SWG Pool Taste Salty?
    Yes, the water can indeed taste a bit salty.
    13'x22'x52" 8,000 gallon ProSeries Pool with Borates
    Intex 110 pound Sand Filter with Zeobrite, 2650 gph pump, 0.95 hp
    Bestway SWG
    AquaPro ECO500 50,000 BTU heat pump
    GLI Whirlwind Solar Cover Reel, TF-100 Test Kit
    Sep 2007
    Lafayette, Louisiana
    344
    It varies from person to person. The salt level in a SWG pool is right at most people's taste threshhold. ~3000 ppm. The ocean is ~35,000 ppm.
    Fortune favors the well prepared
    The build...
    viewtopic.php?t=3974
    Freeform 24' x 38' IG gunite. 3 1/2' to 8' deep. 28,500 gallons. AutoPilot Total Control SWCG. Pentair Intelliflo VF. Pentair CCP520 cartridge filter. Colorlogic LED lights. Tahoe Blue Diamond Brite. 1200 sq ft stamped concrete deck.
    More details as they happen...
    Jul 2011
    844
    Belldiver is correct. It varies from person to person. The recommended salt level for my SWG is 4,500 (higher than most). My daughters can easily taste the saltiness in the pool but I cannot.
    Bestway SWG
    Aug 2010
    Dallas, TX
    4,052
    I can taste it just above 1000ppm. I can certainly taste it at 1500ppm. Some people get in my pool, which is now at 4800ppm (that's a different story) and they don't taste it.
    I don't like salty food, either.
    Glock30's Avatar
    Apr 2012
    Massachusetts, USA
    90
    I have a slat ppm of 3400-3600 and I can only taste it the first time I go in for the day anfter that I cannot.
    I get the salt taste comments too but it does not seem to be a complaint.
    18' X 36' Inground Pool 26,000 gallons. SuperMax 27mil/27mil Vinyl Liner-Installed Fall 2011
    Pentair Intellipro Programable Pump (Model 011018) // Pentair S8M 500 Cartridge Filter // Circupool RJ45 Salt Chlorinator
    2 Hayward Skimmers // 3 Returns // 2 Savi Melody Pool lights // TF-100 Test Kit.
    Jul 2011
    294
    Thanks folks....and, no, we haven't had any complaints about the salty taste...just comments. I wasn't sure, though, if this is normal, or if, under normal circumstances, there should be no salt taste.
    Good to know everything's as it should be. (That's why this forum's the best!).
