Results 1 to 8 of 8
Thread: water is crystal clear, but algae continues to form on walls
    May 2011
    Montgomery, TX
    176
    pool is a year old, inground gunite with white quartz finish. seems i have to brush about every other day to keep the light green algae off the walls, especially in shaded areas. it comes off fairly easy. water temp has been around 90. always keep my chemicals around 3-4 chlorine, ph 7.5ish, ta 80.
    is it somewhat normal for algae to grow on walls in the summer? thanks
    Aug 2010
    Dallas, TX
    4,052
    Re: water is crystal clear, but algae continues to form on w
    Need a full set of numbers to tell you if your chlorine level is correct. Can you post a CYA number? How do you chlorinate the pool?
    Sounds like you need to read up on "How to shock your pool" in Pool School.
    pool-school/shocking_your_pool
    May 2011
    Montgomery, TX
    176
    cya around 60, ch about 300. i have been chlorinating lately with pucks but will prolly stop soon and switch back to bleach as the cya approaches 80.
    Administrator Leebo's Avatar
    Jul 2011
    Eastern Ohio
    7,112
    Do you have a salt water generator?
    No algae is ever normal. How often do you fully brush the pool, walls and all? Also, at 60 cya your FC is a bit low. It maybe worth your time to boost it up some. I'd go 5fc at the lowest.
    Aug 2010
    Dallas, TX
    4,052
    Your CYA should be around 40 for a normal pool, 70-80 for a salt water pool chlorinated by a salt water chlorine generator. The range for chlorine (FC) for a CYA of 60 is 5-9, which means you've been holding your FC too low. You almost certainly have to shock the pool at this point. Please note that shocking is a process, not a one-time addition of something you buy from the pool store.
    May 2011
    Montgomery, TX
    176
    Quote Originally Posted by Leebo
    no, no swg. i really think if i had a slightly darker finish i would not be able to see it at all. water is clear, and it does not form on floor, just the walls especially in shaded areas. guess i'll shock it good and see if that helps.
    Aug 2010
    Dallas, TX
    4,052
    Please see my notes above your last post. "Shocking it good" is a process, not a one-time addition.
    susa's Avatar
    Oct 2010
    Deep South
    578
    On a few family pools we solved this issue by running pump longer, in some instances 24 hrs, brushing daily and maintaining free chlorine high until walls clear
    Having swcg helps as it allows temporary elevation of performance and variable speed motor allows long runtime at low expense
