Thread: ph prbs
    Jul 2008
    Bucyrus, Ohio
    108
    ph prbs
    ok numbers...
    Ph..6.8
    fc 5
    ta 90
    cya 40
    New water Memorial day weekend as we put a new liner in....I have added ALOT of borax like 64oz 1 week ago and STILL no change in Ph...what am I doing wrong...everything else is good...water clear...should I just leave it alone?
    Overwhelmed
    Pool size: 15' X 48" AG vinyl liner, 5300 gallons, Hayward S166T filter and 1hp pump
    Re: ph prbs
    The common PH test will report any PH below 6.8 as if it was 6.8. So your actual PH was presumably much lower than 6.8 to start with.
    Continue raising PH until you get to at least 7.2.
    cubbybeave08's Avatar
    Feb 2008
    Northwest Indiana
    902
    Re: ph prbs
    And Remember Borax isn't as concentrated as the stuff you buy at the pool store...I used two entire 4 pound boxes a couple of years ago to raise from 7.0 to 7.5...
    If you are using Borax...it will take more than if you use PH up...or other products...
    Beave
    Aqua Leader 24ft Round AG Wil-Bar Influence w/54 inch walls 13,500 gallons
    Swimline J-Blue Opal Liner, 1 4X20 Fafco Solar Bear Solar Heater
    Hayward 2 HP Swim Pro Voyager Pump Micro 150 with 4 way timer
    Swim Pro Voyager Filtration System with Hayward ABS Pearl wide mouth skimmer
    Jul 2008
    Bucyrus, Ohio
    108
    Re: ph prbs
    used the pool calculator and put in by volume the amount to raise it from 6.8 to 7.4 and tested this morning...we are setting perfectly at 7.4
    LOVE being able to use the BBB method and not spending $$$$$$$ at the pool store!!!!!
    Thanks so much!!!!!!!
    Overwhelmed
    Feb 2008
    Northwest Indiana
    902
    Re: ph prbs
    Quote Originally Posted by jshinklin
    Now you're talkin'...I love it when stuff comes together
    Beave
