Results 1 to 12 of 12
Thread: Should I be doing anything else if the water is really clear?
    Nina Li's Avatar
    Jun 2012
    Tampa, Florida
    98
    My pool has been up for a little over a month...haven't done a thing to it (ex cept adding salt when I filled the pool)and it's still perfectly clear. I use my soft mop on the walls just before I turn the pump on for 8 hrs a couple of times a week and it filters out what I loosen up (very little algae). Still clear and inviting. Should I be doing anything else even if the water is really clear?
    22,551
    Re: Should I be doing anything else if the water is really c
    If you're seeing some algae you definitely should be doing something else.
    cramar's Avatar
    Nov 2010
    Sault Ontario
    1,143
    Are you testing the water regularly?
    Test levels will dictate action.
    Nina Li's Avatar
    Jun 2012
    Tampa, Florida
    98
    Thanks for your replies....I"ll start testing...water looked clear. Better safe than sorry..don't want to wake up to a swamp one day.
    38,318
    Unfortunately, it sounds like it is already on its way to a swamp if you have visible algae. Post a full set of test results ... you should then likely start the shocking process.
    Nina Li's Avatar
    Jun 2012
    Tampa, Florida
    98
    This was taken a few days ago.it's really not visible yet, and don't want it to be!!
    IMAG0637 by puying_7, on Flickr
    38,318
    Hard to call that a swamp ...
    Nina Li's Avatar
    Jun 2012
    Tampa, Florida
    98
    aha..thank you..hopefully it'll stay that way.
    techguy's Avatar
    Jul 2010
    Antelope, CA
    2,687
    it will if you test and add the only the chemicals required to keep it so. Around here that's pretty much only bleach, borax, baking soda and the occasional muriatic acid or CYA to meet specific needs... and only when the tests support it.
    -- Guy --
    Nina Li's Avatar
    Jun 2012
    Tampa, Florida
    98
    What do you mean "the fingers"...?
    techguy's Avatar
    Jul 2010
    Antelope, CA
    2,687
    I assume you mean me and my signature comment. This is not my filter but mine looks the same.
    [attachment=0:3aoerd67]ImageUploadedByTapatalk1340434556.028723.jpg[/attachment:3aoerd67]
    This is what the inside of my filter looks like. I have a Hayward Perflex and to my knowledge, it is the only one that looks like this. When I am changing the DE (recharging) my filter, this part comes off the top of my filter body and I use a garden hose to clean off the old, dirty DE and the dirt stuck on the fabric looking materials that cover the "fingers" of the filter. I don't know what's inside them but it looks like tubes with springs inside.
    Unless you have a Perflex filter, you will not have these inside your filter.
    Edited for context and clarity
    -- Guy --
    Nina Li's Avatar
    Jun 2012
    Tampa, Florida
    98
    Aha..I see now...I have a cartridge filter and I hose that down too...about once a week. Thanks for explaining that to me. Never saw one like than before.
