Thread: Question - Bad pump, filter pool combo
    I have been banging my head against a wall now for about 6 mo. Every time I vacuum, I get very fine particles back into the pull. The vacuuming part is fine, its the filtering.So much that my once sparkling water with a very dirty floor, becomes very turbid. I have backwashed a few times. I have used a lot of clarifier, netting over the skimmer basket, and this gel block from in the swim. Nothing filters this water clean. The guys at the local store say fill it up and then vacuum the dirt and water out. Seems like a waste to me. This has not just started, but began when I first started vacuuming when the pool was new last July.
    So, I was wandering if there could be some channeling going on in the filter. Here is my setup stats.
    Above ground 54", 27'
    Gal 19300
    Pump - Hayward Powerflo (EP1550LX)
    Sand Filter - Hayward SW256t / vari-flow xl valve (filter flow rate 80 gpm, max pressure 50 psi)
    Pipping - 1.5" flex intake, pvc out to Hayward auto-clorinator then two returns right above each other
    Pressure stays around 11 psi regardless of backwashing.
    I have seen elsewhere that the pump is rated at 86 gpm and then in other places only 40 gpm.
    I figure I need 40 gpm to turnover that much water 3 times.
    Thoughts?
    Thanks.
    AP
    22,548
    Re: Question - Bad pump, filter pool combo
    Welcome to TFP.
    I doubt it's channeling since it started when the system was new.
    If you tie or hold a sock over the return(s) when vacuuming does it catch anything? Use a thick sock.
    CUTiger78's Avatar
    May 2009
    NoVA
    460
    I've had the same problem and the only solution I found was to vacuum to waste.
    I have considered vac to waste, but return the waste to the pool through a Slime Bag. That way I won't lose lots of treated water. For some reason, I'm not having nearly as much debris return to the pool this year during vacuuming, so I haven't put the Slime Bag option into play.
    Good luck!
    36K gallon 42X22 gunite/plaster kidney-shaped IG;
    1 hp Hayward Super Pump (new in 2012);
    Hayward S244T sand filter w/ Zeosand (both new in 2009);
    175K BTU LAARS Lite2 LG natural gas heater; Polaris 380;
    TF-100 test kit.
