FC Loss Each Day
May 27, 2011
57
Can someone tell me the average daily loss of fc. It seems my loss each day goes down 2 to 3 ppm. My pool is in full sunlight all day & temp is now 90 or higher. I usually add more bleach than the calculator suggest I add,but don't want fc to drop below my target of 6. Thanks for all advice. FC 6,ta 80,ch 50,cya 40/50,cc 0,ph 7.7
If we consider the CYA to be 50 then your target range is 4-8 ppm according to the pool calculator, so you could bump up the FC a little if you want. 2-3 ppm of loss during the summer is normal.
mdreese said:
So pretty much you are adding bleach everyday? Since we just got really hot here in Pa I have noticed the bleach consumption increasing. What do you do when you go on vacation?
-Phone-a-friend
-Float some pucks
-Hope
Raising to shock level and covering the pool can give you more hope.
