Results 1 to 9 of 9
Thread: FC Loss Each Day
    FC Loss Each Day
    Can someone tell me the average daily loss of fc. It seems my loss each day goes down 2 to 3 ppm. My pool is in full sunlight all day & temp is now 90 or higher. I usually add more bleach than the calculator suggest I add,but don't want fc to drop below my target of 6. Thanks for all advice. FC 6,ta 80,ch 50,cya 40/50,cc 0,ph 7.7
    20X40 IG,33,000 GAL,VINYL LINER,1 HP PUMP,HAYWARD SAND FILTER,CAMDEN,S.C.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,970
    Re: FC Loss Each Day
    That sounds normal.
    If it's full sun, you might want to raise the CYA a few points to cut down on losses.
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,377
    If we consider the CYA to be 50 then your target range is 4-8 ppm according to the pool calculator, so you could bump up the FC a little if you want. 2-3 ppm of loss during the summer is normal.
    Love TFP? Become a
    TFP Supporter!
    22,544
    If you can get the loss down to 2 ppm per day, you're doing good.
    So pretty much you are adding bleach everyday? Since we just got really hot here in Pa I have noticed the bleach consumption increasing. What do you do when you go on vacation?
    17x33 inground vinyl pool, 22,000 gallons, 1 1/2 hp hayward pump, Hayward systemII DE filter with chlorinator, north central pennsylvania, heater
    38,262
    Quote Originally Posted by mdreese
    -Phone-a-friend
    -Float some pucks
    -Hope
    Raising to shock level and covering the pool can give you more hope.
    Wow thanks for the quick reply...I like the "hope" i think the phone a friend idea is in my future.
    Puffin's Avatar
    Jul 2010
    Metro Atlanta, Georgia
    217
    -Hope
    lol. This one never seems to work for me.
    19,600 gal, Vinyl, Grecian L, StaRite Dura-Glas 1 HP pump, 3/4hp booster, Pentair Clean and Clear 420 Cartridge filter
    The Pool Cleaner 4x, PoolSkim
    38,262
    I think a little bit of hope is required with any of the options
