Results 1 to 14 of 14
Thread: 15 ft x 48 in Metal Frame Pool Set installation
    Aug 2011
    Cochranville, PA
    228
    I ordered an Intex 15 ft x 48 in Metal Frame Pool Set to replace my old inflatable ring pool. Last year I used sand and leveled the old pool. I have no level areas in my yard. This year I had planned and started to build a large sand box for lack of a better term. It will be square consisting of 3 walls. The side without the wall will be the highest point of ground and the side walls will be triangular following the contour of the ground. The 3rd wall will simply be a rectangle. I was going to put in a weed barrier just to be safe and fill with sand. The tops of the walls would be the top of the sand and level. I was going to place some sort of patio stones where the metal frame touched the ground to disperse the weight. They would be level with the sand. Then cover that with the ground cloth and install the pool. The walls of the box are going to be held in with 4 by 4 posts that will be buried about a foot each. All treated lumber that will be sealed or painted. There is about a foot difference over a 16 feet span(which is the reason for building the box. I was looking over the instructions they mention placing the pool on an absolutely flat surface. Which is the reason I am building the box. And not to set it up on sand. I truly believe that what I am building is well beyond my needs and will work for pool but would like to hear some thoughts.
    1) The size of your pool in gallons 4440.
    2) The type filter you have is an Intex 28651EG Krystal Clear 3000 GPH sand filter
    3) If your pool is an AG (above ground)
    4) Intex 15 by 48 metal frame.
    Southeastern, Pennsylvania.
    Samantha Sabrina's Avatar
    Apr 2012
    Bloomsdale, Mo
    346
    Re: 15 ft x 48 in Metal Frame Pool Set installation
    If you haven't already read here: here-is-how-to-properly-install-an-ag-pool-t47619.html
    Samantha
    In the process of building for a 22' Intex Ultra Frame, (completion date up in the air at this point).
    We could not beat our backyard into submission so we "Buried It".
    Aug 2011
    Cochranville, PA
    228
    That is similar to what I had planned to do. Looking at the diagram I will probably put poly on top of the sand and try to create a sealed area do there will be no water penetration into the sand. I will also look into screening instead of the sand. My septic system is near by and because of that I chose to box in the area instead of digging a level surface.
    Apr 2012
    Bloomsdale, Mo
    346
    If you try to build up a foot to level without the proper equipment you are going to have problems with your pool settling, more so if you use sand.
    Even the screenings that deep will have to be wet down and compacted really good in order for it to support the pool properly.
    Adding about 6" of screenings, wetting it slightly and the let it dry on top and using a hand operated vibrating compacting machine, and then adding another 6" and repeating will help greatly, but it is going to take allot of compacting.
    This is the very reason I started that thread showing the proper way to level your pool site, what you are planning is possible, but requires the proper equipment, time and patience to make it work.
    Check out our project, (link in signature), notice the start date and how long we have been working on it to get to where it is now, and it is still NOT ready.
    Samantha
    For what it is worth, and that may not be much, I had a contractor level my site (for last year's set up) and he built up (in some places about 10 inches, I think) with "crushed rock" (which may be what Samantha is talking about). I had no trouble at all.
    POOL: Intex ultra new in 2014 (32 x 16 x 52) (seasonal; on concrete pad covered with 1.5" extruded or whatever foam insulation sheets - ugly, but comfy); added a through-wall skimmer; I add salt for feel. EQUIPMENT: Pentair SuperFlo pump (1HP, 2SPD); Pentair cartridge filter (200 sq. ft); Pentair MasterTemp natural gas heater (400,000 btu) Climate/Location: Eastern Nebraska
    Apr 2012
    Bloomsdale, Mo
    346
    Quote Originally Posted by crek31
    Note the "key" here is he had a contractor level the site, thus proper equipment to ensure it was properly compacted.
    Yea I guess "crushed" stone would be something like screenings, except it is more expensive, screenings are what is left over after they "screen/sift" out all the larger rock, basically it is considered waste, so they sell it CHEAP, lol, better to get something for it than nothing, plus it really doesn't cost them anything extra to make it, just left over material.
    Samantha
    Aug 2011
    Cochranville, PA
    228
    I understand what you guys are saying. Not sure what I might end up doing.
    Aug 2011
    Cochranville, PA
    228
    Is there a special foam you use under the pool?
    I use 1.5" extruded polysterene (something close to that) -- I don't think there is anything magical about the depth, I just found the price point I was comfortable with. I store it with a giant tarp wrapping it on the side of the house and it has lasted several years -- the more level your site, the less it will crack and the longer it will hold up. I just followed advice on TFP for the extruded stuff, others have opined that is definitely what you want. I recently saw that someone used fan-board but I have not seen if they are happy with it. That is way thinner, but also a ton cheaper. I had considered it, but chickened out and spent about double on the 1.5 inch stuff.
    On cement this year, I love having the foam for feel. On dirt in years past, I loved it for feel and also for having a nice smooth floor that was easy to vacuum.
    Aug 2011
    Cochranville, PA
    228
    I was wondering if anyone had any luck using different thicknesses if foam. Like half the pool on 2'' and the other half on 1". Just trying to save my back some pain.
    Jun 2012
    Allentown, PA
    95
    If you think your compacting is good you can test it to be sure. For water a 48" stack 1" x 1" weights roughly about 1.8 pounds. If you go four times this as a safety factor you'd have a weight of about 7 pounds. If you place something this weight of about 7 pounds per square inch and it doesn't sink in you're good. If it does your compaction isn't sufficient.
    I happened to have a 3' long 1" x 1" steel bar (valued about $60 retail) because I do some machining. This bar weighs 10 pounds (28" long weight about 7 lbs). I used this to test my compaction and I did raise the ground on one side. If you find steel in a scrap yard you can get it for about 50 cents a pound.
    You can use a similar method to test it.
    Aug 2011
    Virginia Beach
    295
    I'm the guy with the fanfold under the pool. I'm happy with it so far. It's been about a month and I can still feel it. I leveled the ground as best I could by swinging a 2X4 around a pivot bar with a level on top. I then added some sand and kept running that board in circles until it was level. It's not perfect, but it's as close as I could get it and it's within spec.
    I put the fanfold on top of the sand, and I used pieces of masking tape in several places on the seams. My thought was that I just needed it to stay in place until the pool was filled. I did notice yesterday what looks like a small wrinkle that I don't think was there, I'll look into it when the weather clears up. On a brighter note, the rain today added an inch or so to my low water level.
    Intex Ultra Frame 18' X 48" 7600 +/- gallons
    Columbia 50 LB sand filter/ HP pump, $$ WELL spent(2nd best thing bought for the pool)
    Virginia Beach, VA
    TF100 test kit- Money WELL spent (best thing I've ever bought for the pool)
    Leisure bay hot tub
    Aug 2011
    Cochranville, PA
    228
    So I moved the location a bit to save myself some digging. I am going to dig the whole pool area. I was wondering in the lowest area if I could double up the foam. I assume that it will compact twice as much as the area that has a single layer of foam. I imagined that the foam would be a few inches larger than the liner and the stones would sit on the ground a inch or so away from the foam.
    Aug 2011
    Cochranville, PA
    228
    Been digging a lot. and the pool is about half way filled up! How close or far away should the feet be from the liner. I know everyone mentioned they move outward as you fill but mine haven't moved but a .25 inch or so. I still have the ability to adjust them a but not sure what my goal should be.
