Thread: Pool weir?
    Pool weir?
    My pool never had one until today. Will I see a big improvement in the cleanliness of the top water of my pool? Primarily all the bugs I have been getting?
    25k Gallon Gunite Inground Pool
    Pentair FNS PLUS DE filter
    Pentair WhisperFlo WF-24 (seems like single speed)
    Bel Air, MD 21015
    38,303
    Re: Pool weir?
    Yes.
    EDIT: assuming the wind cooperates ... if the winds here are going the wrong way ... all the floaters stay on the wrong end of the pool.
    Re: Pool weir?
    Does the weir have to fit super tight? Mine had like an 1/8 inch on each side. But after I pulled the plugs it stayed in place. Will I be ok or should I have tried to get one that fits perfectly?
    Bel Air, MD 21015
    38,303
    Re: Pool weir?
    Well, it needs to move freely, so you can not get one too tight. Odds are that will work. The point is to keep the stuff in and not be able to float back out ... it also helps to pull in more from the top.
    Re: Pool weir?
    Do I still put in the skimmer basket with the weir?
    Bel Air, MD 21015
    22,550
    Re: Pool weir?
    Yes it needs the basket too.
