I have a problem for which I am hoping there is a solution. My main drain cover is off and my "pool guy" says that the collar or flange that you screw the cover into is broken and that the cover cannot be screwed down. He says there is no way to repair this except when the pool is refinished.
Is this accurate? I am hoping for someone who may know of some product to help resolve this.
Can I use a glue to glue the cover down? I would be fine with that. My pool will likey need to be re-done this winter so it may only need to be a short terms fix.
Thanks.
Thanks.
