Thread: Filled pool with fresh water -- how to add chemicals
    Over winter and spring we lost most of the pool water out of our 24' round above ground pool because of a leak in the vinyl liner. Only a feet of water was left in the pool as the hole was at the bottom of the pool.
    Since then i have identified and patched the leak and am filling it back with water. I am relatively new to maintaining a pool. I need some advice on how to go about adding chemicals to the pool before we can start using it.
    Which chemicals should be added first ? Any guidance is most welcome.
    I have the test kit recommended in this web site.
    Pool Capacity 18k, Filter Type is sand, Salt/Chlorine-Turbo Cell, Aqua PLUS, Pool is gunite IG, Pump Size is , Flow Rate is ,
    Jun 2012
    Long Island, NY
    102
    Re: Filled pool with fresh water -- how to add chemicals
    Check this out, this is what I am following - > pool-school/temporary_pool_guide
    Thanks - John
    Pool: Sharkline Matrix 18 Round 54 Deep
    Pool Size: ~8200 Gallons
    Filter Type: Sand
    Pump: Intex 2650
    Articfox918's Avatar
    May 2012
    Western, Wisconsin
    99
    Welcome to TFP!
    First off you need to read and re-read Pool School! Then if you need further assistance everyone here is willing to answer your questions
    POOL SIZE: 27 FT round 52" Deep on edges 66" Deep in center
    FILTER TYPE: Hayward Sand Filter
    PUMP SIZE: Hayward 1 HP Pump 60GPM
    FILTER SIZE/FLOW RATE: Unknown
    HEATER: None at the moment but in process of making my solar panels should be operational by next season!
    Thank you for pointing to the right resources. Will definitely drill down for more info and keep posted..
