Page 1 of 2 12 LastLast
Results 1 to 20 of 22
Thread: Acceptable salts?
    GreatCanadian's Avatar
    Jul 2011
    St. John's, Newfoundland
    844
    Acceptable salts?
    Was shopping for salt for my pool today. 11 bucks a bag for pool salt!! $4.29 for Windsor System Saver 2. There was no indication of any additives on the bag, but I want to be 100% sure that it's ok before I buy it. Any opinions? Here's a link. It's the first one: http://www.windsorsalt.com/water_soften ... 1.html.htm
    Thanks for any advice you may offer.
    GC
    13'x22'x52" 8,000 gallon ProSeries Pool with Borates
    Intex 110 pound Sand Filter with Zeobrite, 2650 gph pump, 0.95 hp
    Bestway SWG
    AquaPro ECO500 50,000 BTU heat pump
    GLI Whirlwind Solar Cover Reel, TF-100 Test Kit
    Aug 2010
    Dallas, TX
    4,052
    Re: Acceptable salts?
    Looks good. Here's what I use, even cheaper.
    http://www.homedepot.com/h_d1/N-5yc1v/R ... reId=10051
    WindsorŪ System Saver Formula II and WindsorŪ Select Plus are both fine. Avoid WindsorŪ Rust Remover, as it has an added rust remover.
    Jul 2011
    844
    I keep reading about Diamond Crystal here on the forum. Why can I not find it here?? Is it not available in Canada? Is it under another name?
    Thanks guys. I appreciate it.
    GC
    Bestway SWG
    Aug 2010
    Dallas, TX
    4,052
    I found this humorous. Kind of like a jar of peanuts that says "may contain peanuts or may have been processed in a plant that also processes peanuts"
    Jul 2011
    844
    Quote Originally Posted by RobbieH
    LOL...Just noticing that now. It is good for a chuckle indeed!! I'm sure Jason posted it tongue-in-cheek!
    Bestway SWG
    Jul 2011
    844
    Also, there were a couple of pellets spilled out of the bag at Walmart. Those are BIG pellets. Over an inch long and over half an inch wide would be my guess. They'll dissolve ok?
    Bestway SWG
    Yes, they will dissolve just fine. They take an extra ten or twenty minutes to dissolve, which really isn't an issue.
    Jul 2011
    844
    If that's all the extra time it takes, then you're right, it isn't an issue at all. Why do SWG manufacturers recommend letting the salt dissolve for 24 hours prior to turning on SWG?
    EDIT: I have read about Morton System Saver 2 here on the forum but could never find it in a store here in Canada. Just found some info online illustrating the connection between Morton and Windsor salts. Here's a snippet:
    The Canadian Salt Company Limited, also known as Windsor Salt, is a part of Morton International Inc., located in Chicago, Illinois. Together, we employ close to 3,000 people in our salt mines, production manufactories, warehouses and offices throughout the United States, Canada and the Island of Inaqua in the Bahamas.
    Taken from: http://www.windsorsalt.com/careers/index.html
    Bestway SWG
    Salt dissolves really quickly, but the resulting very salty water doesn't mix into the rest of the water all that easily. You want 24 hours with the pump running to make sure the salty water is throughly mixed into the less salty water and the salt is uniformly distributed.
    Jul 2011
    844
    Perfect. Great explanation Jason. Thanks.
    GC
    Bestway SWG
    Feb 2008
    Milford, CT
    333
    FWIW, walmart has actual mortons pool salt for 5.79 per bag. I know its not the cheapest, but for actual pool salt (that is very finely ground) it seems to be a good price.
    22K IG vinyl, .5HP Northstar pump, S244T filter, AutoPilot Digital w/SC-48 cell
    Samantha Sabrina's Avatar
    Apr 2012
    Bloomsdale, Mo
    346
    Why pay an extra couple of bucks just to get a bag that says "Pool Salt" when "Water Ssoftener" salt is the same thing?
    Samantha
    In the process of building for a 22' Intex Ultra Frame, (completion date up in the air at this point).
    We could not beat our backyard into submission so we "Buried It".
    Feb 2008
    Milford, CT
    333
    Quote Originally Posted by Samantha Sabrina
    Pool salt takes a little less time to dissolve.
    Mostly I ordered it because I could order it for pick up in store, so the 12 bags I needed were on a cart and ready to go saved a little time and back pain. For the extra 12.00 (1.00/bag vs water softener salt from HD), it was worth it.
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    I hope you had a truck to tote those 12 bags or made 2 trips.
    Feb 2008
    Milford, CT
    333
    Quote Originally Posted by bobodaclown
    I find it hard to live life as a homeowner (or even just a pool owner) WITHOUT my pickup truck. So yeah, definitely had the truck with me.
    Aug 2010
    Dallas, TX
    4,052
    Mine took 32 bags. The Diamond Crystal bags were less than $4 each. I ordered them from Home Depot onlne, and they were waiting on me at the store when I got there. I dumped them all in at once, and it was all dissolved in a few hours. If it's worth it to you to pay more for exactly the same thing but with a Morton labelthat says it's for pools, I guess.
    Kind of like that guy a couple of days ago who's wife would not let him use Clorox because it wasn't "made for pools".
    Apr 2012
    Bloomsdale, Mo
    346
    Lol, actually her problem was Clorox is for doing laundry!
    Anyway, you were inside my head when you posted that! Great minds and all that, giggles.
    So while you are in there, what should I have for breakfast?....If you can wade through the cobwebs that is...
    Samantha
    Jul 2011
    844
    So. I buy 6 bags of Windsor System Saver 2 salt and dump them in the pool. As I'm collecting the empty bags I notice this written on the back. "...contains high purity salt with patented resin cleaning additives". Salt dissolved and SWG seems to be working fine. Will these "patented resin cleaning additives" have any negative effect on my water or equipment?
    GC
    Bestway SWG
  20. Back To Top    #20
    Jul 2011
    844
    Just a week bump
    Bestway SWG
