Results 1 to 9 of 9
Thread: PVC pipe question
    poollizard's Avatar
    Jul 2010
    Apple Valley, California
    26
    PVC pipe question
    See the output port on the Jandy valve in the photo? I need to cut everything off from that Tee downward and put a 2" union on it so I can repipe all the way to the pump. My question is, after i cut the Tee off, that will leave only about a half inch of pipe to glue a 2 inch union onto. Is that enough? If not, I'll have to buy a new Jandy valve and start from the ground up.
    21,500 Gal IG plaster, free form, PAC-FAB NAUTILUS NFS-60 DE filter; Pentair Intelliflo VF pump; TELEDYNE LAARS Series One gas heater. Hayward PoolVac V-Flex pool cleaner. Taylor K-2006 test kit.
    38,274
    Re: PVC pipe question
    I see no Tee that you are referring to (pic is too close I think).
    Looks like you will have to replace a lot more than planned due to the lack of free pipe anywhere around that valve.
    ALTHOUGH ... you may be able to use a coupler on the outside of the valve to a larger pipe and save the valve.
    Jandy valves accept the next larger size pipe fit over the outside of the fitting, so this should be fairly simple.
    poollizard's Avatar
    Jul 2010
    26
    Sorry for not being more clear. That fitting on the south end of the valve is a tee. Down goes to the pump, right goes to an old spa line that's not used any longer. I want to eliminate that, and repipe from the valve to the pump.
    I will look into a coupler for that port, as you and Jason have suggested. Would that be a 3 inch to 2 inch reducing coupler?
    If the current pipe is 2", the outside connection will take 2.5" pipe, and you can then reduce that to 2" with a reducer.
    poollizard's Avatar
    Jul 2010
    26
    Ah, okay. Off to the store I go.
    Jun 2012
    western NY
    1,560
    There are reamers available to ream out fittings to accept new pipe. They are a bit pricey in the $50.00 range but, if you have an expensive valve to replace I could be worth it. Just figured I would pass this along.
    Unknown make 18' above ground (bought used in 1999) Sparco sand filter. Hayward 100,000 BTu heater. 2 speed pump
    poollizard's Avatar
    Jul 2010
    26
    Quote Originally Posted by danpik
    Thanks for the tip. I went out looking for 2.5 inch PVC pipe. Neither Lowe's nor Home Depot had any. Not sure where to go next. Maybe online? Dunno?
    38,274
    There has to be a plumbing store around that would have it.
    Posted with Tapatalk ... sorry if I sound short ... hate typing on phone
