Thread: Cracked Hayward-Perflex EC40 - repair or replace?
    Jul 2011
    Bedford, NH
    67
    I'm a pool rookie.
    I left my drained Hayward-Perflex EC40 in my garage over the winter, and when I brought it out last month, I noticed the outer plastic casing was significantly cracked. Not sure if someone hit it or it had anything to do with the cold weather.
    Can this be replaced or repaired? Or should I just replace it? If I replace it, I prefer cartridge filters, and I'd likely need to go used for financial reasons. Assuming I use my current pump, how do I determine the right size filter to buy?
    18' round above ground, vinyl liner, 48" deep (flat), Confer Step1 steps. Approximately 7600 gallons. Waterways/Proline FC075 cartridge filter. 75GPM (71 minute complete cycle), 75 sq ft filtration area.
    May 2011
    Berea. KY
    34
    Re: Cracked Hayward-Perflex EC40 - repair or replace?
    Hello. If I where you I would replace the filter because if you tried to fix it it may blow apart when the pump is running then you may burn the pump out and be out a whole filtration system. . For the size filter I would look at the square footage and gpm decal on the side of your filter to determine what filter you will need. Hope his helps
    Cole Pocius
    15'x30'x52" AG, 1 HP Hayward Power Flo, Hayward per-flex D.E filter, Aqua luminator. chlorine, baracuda beta. vinyl liner, 12,500 k gallon
    Jul 2011
    Bedford, NH
    67
    Here is the information on the side of the filter and the pump. I assume since I have such a small pool (15' round) that I'm ok with any filter I see on Craigslist from a larger pool? If not, what specifications are most important? And is there any reason for me to replace the pump?
    May 2011
    Berea. KY
    34
    hello, any filter will work for your needs as long as it is a Hayward DE filter with the model number, EC-40, EC-50 or EC-50C. now to the pump, it should be ok. BUT, if you can find a whole system that is less than 4 years old on craigslist for less than $200 bucks you would have a great deal and any size hp or gpm pump should do. if you do find a pump, keep it for a spare like i do just in case something may happen to your pump. hope this help and you get you pool running soon
    Cole Pocius
