Thread: Pucks and CYA
    tcat's Avatar
    May 2012
    Austin, TX
    731
    Pucks and CYA
    How fast does CYA rise per 3" puck per 10K gallons? I am switching to liquid 6%, but I have a few pucks left. My auto chlorinator is set at "3". I have 1 more week of pool service before I take over(they are using liquid). I just drained 50% to get my CYA down to 65. Should I just turn the chlorinator to zero, or let them run out and not add more?
    IG pebble, 15,000 gallon
    48 PentAir DE Filter with backwash valve
    PentAir Whisperflo pump with 1hp 2-speed motor
    Aquabot 4WD, Poolskim
    Intermatic Dual Timeclock with freezeguard
    DIY chlorine feed
    BBB
    Aug 2010
    Dallas, TX
    4,052
    Re: Pucks and CYA
    You can use poolcalculator.com to calculate how much CYA will be added to your pool.
    38,281
    Re: Pucks and CYA
    Using the calculator, each puck is approximately 3ppm CYA (depends on the weight of the pucks)
    tcat's Avatar
    May 2012
    Austin, TX
    731
    Re: Pucks and CYA
    Wow! I think I'll turn it off and remove the pucks... CYA is probably back up to 75-80...
    DIY chlorine feed
    BBB
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,995
    Re: Pucks and CYA
    Pucks have a long shelf life if they are kept sealed up. Save them for vacation.
