Thread: What to do with the testing water
    frogman_94's Avatar
    Jul 2011
    Cameron Park, CA
    16
    What do you do with the testing water? Currently I just dump it on the ground. My ground is just dirt for now.
    13x25 SplashPool (10,600 gal) AG
    20" Sand Filter with 1HP pump
    Aug 2010
    Dallas, TX
    4,052
    Re: What to do with the testing water
    Sounds good to me, just don't put it back in the pool. The best would be to put it down your sink drain. I will mention it may be easier to bring a big sample of water to the house, that way you can sit at the table and do your testing. Then you can put all the test water down the drain.
    frogman_94's Avatar
    Jul 2011
    Cameron Park, CA
    16
    I use the bottle I got from Leslie's and do my testing in the garage. I just wasn't sure if it was OK to dump the samples down the sink.
    Leslie's is good for something.
