Thread: I have a dumb question...
    bwiley47's Avatar
    Princeton, WV
    97
    Since the DH decided to drain the pool and clean it this year we now have fresh water. Since Sunday I have added 3 bags of shock and 2 pucks, In order to get my cya up, since it registered 0 when testing. (We have city water). The kids swam alot yesterday and we've had some hot days along with a downpour on sunday.
    Here are my results this morning.
    FC 0.5
    CC 0.5
    TC 1.0
    TA 60
    PH 7.2
    I know I need to get my TA and PH up, and some chlorine in there. Should I just assume my cya is still 0 and check it on Sunday(since it takes up to a week to register?)
    Thanks!
    16 x 32 AG Fanta Sea 13,500 gal/ Hayward Sand Filter/ 1 hp Hayward Power Flo LX Pump
    1 skimmer 1 main drain
    Aug 2010
    Dallas, TX
    4,052
    Re: I have a dumb question...
    TA at 60 is nothing to worry about. Consider yourself lucky. pH can be brought up with a little Borax, or from kids splashing. You can't assume CYA is 0 because you added "shock" and pucks. You can use poolcalculator.com to estimate the effects of what you added.
    38,246
    What kind of shock did you add? Anything under 20-30ppm of CYA may show the same on the test. First priority is getting FC up and adding CYA. pH and TA seem fine for now.
    Posted with Tapatalk ... sorry if I sound short ... hate typing on phone
    bwiley47's Avatar
    Princeton, WV
    97
    Thank you both. Not sure what kind of shock I added but will check it out and use the pool calculator as suggested.
    22,542
    If you haven't already, you need to get some FC in the pool now.
