Thread: Pool Pilot technical questions
    Feb 2008
    Milford, CT
    333
    Got my pilot digital up and running, had a couple questions (mostly out of curiosity):
    1. Ive seen references to expected cell voltage and amperage levels. I know the amperage is based on chosen power level, but is there a chart/listing stating what expected voltage should be? For instance, my brand new system is running at 25V, 5A. I know Sean has mentioned a couple times expected cell voltage is 24 to 28, I was curious if there is a full chart that shows expected voltage and amperage based on salt level, water temp, etc.
    2. Can you use the cell voltage and amperage as a way to more accurately determine the salt level? Since the volts and amps seem to adjust based on how much salt is in the water, is there a way to calculate it accordingly.
    Thanks in advance.
    -Chris
    22K IG vinyl, .5HP Northstar pump, S244T filter, AutoPilot Digital w/SC-48 cell
    Re: Pool Pilot technical questions
    Cell Power 1 = 5.0 amps
    Cell Power 2 = 6.5 amps
    Cell Power 3 = 8.0 amps
    The voltage varies depending on salt level, temperature, etc. If the voltage goes above 27 volts something is wrong (low salt, cell failing, cell scaled, etc).
    The unit calculates the salt level for you. It depends on just on amps/volts but also on temperature.
    Feb 2008
    Milford, CT
    333
    When I first started the unit it was at 27V, 5A. Sean mentioned it seemed high (RC42 cell)
    It eventually went down to where its at now, 25V, 5A.
    Should I play slave to those numbers? And add salt to get it down to 24V?
    My strips were showing ~3200, the unit is showing 3200. Sean recommended 3500.
    Unless something is going wrong you should completely ignore volts and amps. Just keep salt roughly in range and let the SWG do it's job.
