Thread: Hot tub in hotel
    dorpo75's Avatar
    Jul 2009
    NE Ohio
    256
    Hot tub in hotel
    The hot tub in the hotel at which we are staying has foaming bubbles on the water when the water is churning at any speed. The high speed has a TON of bubbles and foam. Is this normal or should we stay OUT?
    2005 Dimension One Venture model 370 gal. hot tub. We'll be using the TFP method to keep it clean and ready to use!
    TFP - The Finest Phorum on the Net!
    Samantha_in_AL's Avatar
    Apr 2010
    Altoona, AL
    242
    Re: Hot tub in hotel
    It could have had a hefty dose of algaecide lately.
    AG 18' X 52" Round Pacifica Pool w/ Metal Diamond Unibead Liner. Installed in March 2007.
    2.5 HP Baquapure 2 Speed Pump, 200 GPM Waterway ProClean Cartridge Filter System.
    Former Baquacil user
    Converted to BBB in Fall of 2009 - Now I have a truly trouble free pool!
    Aug 2010
    Dallas, TX
    4,052
    I won't get in a pool or spa at a hotel. Knowing what I know now has ruined that.
    FYI, some folks here take their test kit with them and test the water before they get in. I haven't done it, but yes I'm that paranoid.
    Mar 2007
    San Rafael, CA USA
    12,082
    It's most likely just soap from people who didn't rinse/shower off before getting into the tub. Hot tubs usually don't have algicide added to them and in a commercial/public spa it's likely they are just using chlorine directly without any CYA. So if anything, the chlorine will be too strong.
    You could not pay me enough to get in a public Hot Tub. Unless you like soaking in strangers urea. And worse...... In my opinion.....STAY OUT
    Plus you are counting an a minimum wage person to control the sanitizer in the tub... no thanks.
    Barrier Reef Pacific1-Pacific color 37'9" X 14'1" fiberglass IG ~ 17,500 gallons, FHPM1.0-2 Jandy FloPro pump, Jandy Aquapure 1400 SWG, Waterco Multicyclone 16 pre filter, Jandy CV580 filter, 3 PAL-2000 RU LED lights, 1 skimmer, 2 main drains, 3 returns, 2" rigid pvc suction and return plumbing, BBB method, TF100 Kit
