Thread: Burying PVC for AB pool
    Sep 2011
    Zebulon, NC
    24
    Hi All,
    We have just ordered our first pool (18 X 40 AG)! It is to be delivered in about 2 weeks and then be installed shortly thereafter. The pump (dual speed), heater (100,000 btu propane), salt generator and sand filter will be about 10 feet from the pool and I am going to start with using the standard above ground plumbing that comes with the install. I will be hard plumbing and burying almost immediately since the pipes will be running in front of my crawl space door.
    I am planning on using Schedule 20 2” PVC buried 12” to/from the pool. My question is about the run from the heater. Will there be any issue with running the PVC from the heater? I know that there are issues with running from household hot water heater with PVC since it could soften and cause leaks. I am not sure if the pool heater get’s hot enough to be a problem.
    Thanks in advance.
    38,235
    Re: Burying PVC for AB pool
    Must use schedule 40 not 20.
    Fittings on the heater should be CPVC but I think you can use PVC pipe after that.
    Posted with Tapatalk ... sorry if I sound short ... hate typing on phone
    Sep 2011
    Zebulon, NC
    24
    Thanks jblizzle! No worries on short responses.
    Thanks for the update on schedule 40, for some reason I think I knew that but convinced myself that schedule 20 was correct. Are there no concerns with running the hot water from the heater through Sched 40 PVC? I am not sure how hot the water is coming out of the heater, I cant find the temp anywhere, but I believe the max temp for the PVC is in the 120 - 140 degree range and that it can soften and start to come unglued if it gets too hot.
    38,235
    Both pools with heaters I have had were plumbed with PVC pipe.
    I don't think the water ever gets that hot. A spa should only get up to about 100 degrees before it becomes unsafe.
