Results 1 to 9 of 9
Thread: At wits end
    At wits end
    I have read several posts and I have to say that I have learned alot from this site, and than you. However..I am still a newb that is going crazy. I have a 24'x48" pool, it is not an intex. I purchased an intex 2650 gph pump/filter. I hardpiped everything and had it running fine until yesterday. My psi is at 0, and I have hardly any flow from the return. I backwashed several times, but when I do this it causes the water in the pump to go down and I have to open the lid for it to fill back up with water(the leaf basket), then I recirculate so that the sand settles, and start the filter again. It will do just fine for about 10 minutes, then the flow goes way down.
    I have gone through the trouble shooting in the owners manual, and I have read several posts, but I still am unable to get this pump to work right and still have cloudy/greenish water and am ready to just put this thing on craigslist and let someone come get it. I am that frustrated.
    As far as the water goes..once we got the pump/filter circulating good, we added shock to out pool..the powder kind. Waiting a few hours..and added another bag of shock..water was still cloudy and greenish color. I put the water on hold until I can get the pump working right since without it it won't really matter anyway.
    Any help and/or suggestions will be so appreciated.
    Thank you.
    Frustrated Dad
    13500 gallons
    Intex 2650 Sand filter pump
    AG
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,023
    Re: At wits end
    Start looking at the skimmer for blockage, stuck flapper, low water, collapsed hoses, valves in the wrong position.
    Samantha Sabrina's Avatar
    Apr 2012
    Bloomsdale, Mo
    346
    Re: At wits end
    I am certainly not an expert here, they will be along shortly, lol.
    It souunds to me like you have an air leak between the pool and pump on the suction side, or the water level is not high enough for the skimmer to work properly. Someone else here figured out their water level was causing pretty much the same issue.
    See, I was too slow, lol...What Richard said!
    Samantha
    In the process of building for a 22' Intex Ultra Frame, (completion date up in the air at this point).
    We could not beat our backyard into submission so we "Buried It".
    At wits end
    The water is coming from a through wall skimmer and is full, only hose is between pump and filter, valve is is filter position.
    Will work fine for about 10 minutes then nothing. Should I be having to open the leaf basket to get it to fill up with water after I backwash?
    13500 gallons
    AG
    Richard320's Avatar
    Jan 2010
    19,023
    Re: At wits end
    Are you sure it's not sucking air, from low water level or stuck flap? You might also be sucking air through the strainer lid or the drain plugs on the pump strainer housing.
    At wits end
    I don't hear anything. Is there test I can do to see for sure?
    13500 gallons
    AG
    Richard320's Avatar
    Jan 2010
    19,023
    Re: At wits end
    Quote Originally Posted by wwhite0310
    Watch in the skimmer for the time it takes to lose prime. You might hear sucking or see a vortex. The drain plugs just need to be snugged with a wrench to be sure they're seated. The O-ring needs to be free of cracks, no dirt or grass stuck to it, and well-lubricated with pool lube. Don't use anything petroleum-based on it, it will probably turn to black mush.
    If all that fails, try running a hose around any pipe joints and valves while its running and see if it helps. If it does, that's where air is entering.
    At wits end
    Ok I can try that tomorrow. It has gotten dark here and I have no lights out there yet. Thank you I will update tomorrow.
    13500 gallons
    AG
    At wits end
    I will try and post picks also.
    13500 gallons
    AG
