Results 1 to 10 of 10
Thread: Pool rookie - Aboveground Pool Questions.
    Thanks to all that have posted on this site in the past...my wife did our family a "favour" :> and bought an AG pool last year and I'm trying to install it now. I have zero idea what kind of pool it is...I can tell you it the base rails measure 23'7" when laid out and round, the top and bottom rails are metal C channel, the wall is 48" corrugated aluminum and there is an aluminum top cap that goes across the top of the posts with plastic caps. Probably not much help, but hey...
    The pool is a 24' sucker that is being installed on what was a 24" grade. I brought in a big shovel on Monday and he got me within 1.5" across the 24'..so far so good.
    I got some 10x10 patio pavers and I have bases for the the 17 posts sitting on those. In some areas the bottom rails are 1-2" off the ground though. My plan is to level the pool base (add a 6" radius on the inside at the bottom) and then add the liner.
    Q - Can the the bottom of the rails sit on packed sand or do they need to be sitting on something more firm. I know the liner will have a lot of downward force, but the walls transmit a lot of downward force to the bottom rails.
    Thanks for any help you can lend,
    T.
    Size: 24' dia ~12,000 gallons
    Filter: 200 lb Jacuzzi sand filter
    Type: Above Ground
    Liner: Vinyl
    Pump: 1 HP Jacuzzi
    Sand filter - Can I use masons (brick) sand?
    Further to my earlier story, I have a sand filter that's empty. I had 9 tonnes of sand delivered to level the pool base and I expect to have a bunch left over. Can I use this sand in the pool filter or do I need something special for it?
    T.
    Type: Above Ground
    Liner: Vinyl
    Pump: 1 HP Jacuzzi
    Center drains - are they required?
    Yeah...me again :>>>
    The pool my wife picked up came with a center filter...in talking with a buddy he said he it was more of a problem then benefit, so I'm wondering if it's mandatory that it get installed. We have a "creepy crawly" to clean the pool, so I'm wondering if the center drain is req'd.
    In addition, does anyone have a plumbing schematic that shows how the strainer, pump, filter, auto chlorinator.....are supposed to be hooked up? The used pool that my wife picked up didn't come with any details.
    Thanks to any help you can lend,
    Tony
    a.k.a. pool rookie.
    Type: Above Ground
    Liner: Vinyl
    Pump: 1 HP Jacuzzi
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Sand filter - Can I use masons (brick) sand?
    No. You need filter sand.
    No prob on the filter sand.....is there a normal amount one needs for a sand filter?
    Type: Above Ground
    Liner: Vinyl
    Pump: 1 HP Jacuzzi
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Center drains - are they required?
    Welcome to tfp, TonySe
    Do you have freezing temperatures where you live?
    I you do (I do), then I wouldn't install the floor drain, since you would need to winterize that every year.
    I do not have a floor drain, and have no desire for one, however, there are some on here who insist it simplifies their cleaning a lot (even some in cold climates).
    How big is the pool?
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Pool rookie Q - bottom rails
    Quote Originally Posted by TonySe
    Something more firm. I used pavers all the way around, but you could also leave undisturbed dirt underneath. Sand is too easy to wash out, so I would not use that.
    Quote Originally Posted by linen
    Do you have freezing temperatures where you live? I you do (I do), then I wouldn't install the floor drain, since you would need to winterize that every year.>>
    Does it freeze? Oh heck ya...I'm on the same latitude as you, I'm up in Ottawa, Canada.
    Pool is 24' round, 48" walls.
    T.
    Type: Above Ground
    Liner: Vinyl
    Pump: 1 HP Jacuzzi
    Sounds good...I'll dig it out a bit more so the bottom is nearly flat and then bury the pavers enough so the rails sit on the ground.
    T.
    Type: Above Ground
    Liner: Vinyl
    Pump: 1 HP Jacuzzi
    Aug 2010
    Dallas, TX
    4,052
    Depends on the capacity of the sand filter. Could be 100 pounds, could be 600 pounds, or anything above or below.
