Results 1 to 11 of 11
Thread: Salt Pool With No Free Chlorine
    Jun 2012
    Hanover, PA
    6
    I am a new member, and I have some problems with chlorine levels. I recently bought the TF-100 test kit. This is my first year with a salt generator. I can't seem to get some if any FC. I have shocked the pool over a 7 day period with 20+ pounds of shock. Water was cloudy but now is clear. I have also been running the Salt Generator around the clock for 10 Days.
    18x36 vinyl pool 20,000 gallons, cartridge filter, aquabot cleaner. Some help would be gratefully appreciated.
    Thanks, jim
    FC 0.5
    CC 0.5
    TA 110
    CH 290
    CYA 40
    Ph 7.2
    19400 Gallons, Vinyl In Ground, Starite Cartridge Filter,
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Salt Pool With No Free Chlorine
    Welcome!
    What generator do you have? What is your salt level?
    Try taking a water sample from the return to see if you are producing chlorine.
    Jun 2012
    Hanover, PA
    6
    Circupool RJ45 Salt level 3800ppm
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,655
    Your CYA is about half of what it SHOULD be for a SWG. What kind of "shock" have you been using?
    Jun 2012
    Hanover, PA
    6
    HTH Super Shock And Swim. Tonight I put in Clorox Bleach. If the SWG's cell is cloudy, is that enough to say it is generating chlorine? I will increase my CYA.
    Thank You, Thank You For The Help. It is greatly appreciated.
    Yes, when the cell is full of bubbles it is generating chlorine.
    Jun 2012
    Hanover, PA
    6
    I put 4lbs of HTH Stabilizer in the pool at 12:15p. I measured the CYA tonight and it increased to about 50. I will check CYA tomorrow again to see if it moves anymore. I will continue to put CYA in as needed. Should I shoot for 80ppm? The SWG is still set at Super Chlor 24 hours a day. I took water from the return using a funnel and hose, there is chlorine. How much chlorine should I see using the Taylor OT chlorine test. It appears to be .5-1, if i let it sit for a couple of minutes it will get more yellow. Is that normal Another thing I didn,t mention is that my CYA was around 65 when the pool was opened up for the summer (5/1), when the pool went cloudy about 10 days ago the CYA was 0. If anybody looked at how clear my water is they would think everything is perfect. That is what is so puzzling to me.
    FC 0.5
    CC 0.5
    TA 110
    CH 290
    CYA 50
    Ph 7.2
    Thanks For The Help
    jim
    38,516
    Be careful. The granular CYA can take a week to show up on the test.
    Not site how your cya could have dropped so much without huge CC numbers.
    Posted with Tapatalk ... sorry if I sound short ... hate typing on phone
    Jun 2012
    Hanover, PA
    6
    We got home from vacation on Saturday and the pool was cloudy. FC 0.0 CC 0.0 TC 0.05 TA 100 CH 370 CYA 40 pH7.3
    I set the pump to run 24hr, and put the SWG to 90% and added 3ea. of 182 oz Bottles Of Chlorox. This brought the FC to 15. Sunday morning the water was not as cloudy FC was 3.0. I added 2ea.of 182 oz Bottles Of ULTRA Chlorox FC now 12.5. Monday morning the water was clear.
    Monday Evening levels are:
    20,000 Gallon In Ground Pool
    FC 1.0
    CC 0.5
    TC 1.5
    TA 100
    CH 410
    CYA 40
    pH 7.3
    Any suggestions for my next step would be gratefully appreciated.
    Thanks, jim
    38,516
    Follow the Shocking Your Pool process ... generally best done with the SWG off so you can understand the FC usage.
    EDIT: I also see that you appear not to have raised your CYA as recommended. Do that AFTER you pass the 3 tests to stop the shock process
    Jun 2012
    Hanover, PA
    6
    Thanks for the information, I will follow the shock procedure and get back when I finish shocking.
    Thanks Again jim
