Thread: pool pump and timer selection
    I have a new inground pool install underway. I have a hayward 1.5hp super pump dual speed and need to know what kind of timer to go with it that will automatically switch between high and low. I guess another question is do I need the timer to control this or can I just manually switch speeds when needed. I will also have a SWG and is there anything special that needs to be considered with the dual speed pump. I will have a single speed pump for the pool cleaner. Any suggestions are much appreciated.
    38,371
    Re: pool pump and timer selection
    Look at the Intermatic lineup. Model depends if your pump is 120V or 240V
    You will need 2 timer dials, but there are boxes that will hold both.
    Assuming it is 240V, I think you need a T104 and a T106. Search the site as I am sure this has been discussed.
    Here is an example:
    http://www.topdogpoolsupply.com/mm5/mer ... ELECTRIC-1
    22,551
    The Intermatic PE-1353 will handle the 2-speed and the cleaner pump.
    Thanks for the suggestions, I will look into these more.
