Thread: TF 100 Question TA is it red or pink
    Jun 2011
    Northern Maryland (near Delaware)
    170
    Ok, I acquired a spped stir, one thing it is cool to watch the colors form a waterspout / whirlpool effect of color changes.
    Anyway,
    cl 6.5
    c/c < .5 slight tinge of red with speedstir light but not visible without light
    PH 7.5
    TA 90 or 100???
    CYA 110 (50% pool water + tap)
    So for CYA drop 9 turned it pink, drop 10 turned it bright red. So would TA be 90 or 100?
    I am just not sure which drop to count as ''red". CYA I calculate around 110 or so, last week pool store told me < 50. Hmmm.
    Thanks
    15'X30'X52" AGP AquaSports Grande Buttress Free (10,620 Gallons), Hayward Dreamline S190 W Zeobrite, 1.5 HP Hayward PowerFlo LX, AquaLuminator Light+ fountain attachment, Pool Rover, Tf-100 test kit, Speed Stir.
    Re: TF 100 Question TA is it red or pink
    For the color change tests, wait for anything remotely similar to the end color (red or pink or anything similar) then continue adding drops until the color stops changing. The final drop, which does not change the color any further does not count.
    It looks like your CYA level is way too high. You need to bring that down to something more reasonable, preferably around 50 to 60. The only practical way to do that is to replace water.
    Aug 2010
    Dallas, TX
    4,052
    Using your FAS-DPD, post what you put up as cl as FC. It helps us know whether it's FC or TC.
    CYA is not a color change test. It's a turbidity test. TA is not measured by the CYA or chlorine test. Your first sentence after the test results do not make sense.
    Read up on the extended test instructions, it will help us all!
    extended-test-kit-directions-t25081.html
    Jun 2011
    170
    Got Me, long day, it was the Total Alkalinity test not CYA, I did the FC Drop test, I don't use that other one much. Yes for CYA I have been draining, I lost about a foot of water the last week due to rain and a popped hose. I am using straight Walmart Bleach, nothing else except some acid a few weeks back when TA was North of 150 and PH over 8. I just don't get it, so I am keeping my FC around 8-9 as a target, which I will add later.
    Based on Jason's reply, drop 9 turned TA pink, 10 red, 11 same red so I am at 100.
    It just irks me before store told me CYA needed to be 100-150, and they pushed it up, now I am stuck, wife will kill me if I keep draining, last water bill very high. I must say since BBB where I have not used Borax in the pool (only to control ants), I have had no algae blooms, but I keep FC higher than reccomended 3-4 which may be a way to sell more chemicals.
    Thanks
    Aug 2010
    Dallas, TX
    4,052
    Correct, TA is 100. That's not horrible. I've been over that and had sparkling clear water. It will come down as you add more MA and let the pH come up on its own.
    The store told you to go to 100-150? WOW!
    Well, last month my water bill was 55,000 gallons (not pool related) so using water is nothing new to me. Our water is $0.005 per gallon here (half a cent). In my case it would be cheaper to drain and refill a pool like yours than to spend $ on chemicals.
