Thread: combined chlorine 1 drop = 0.2 or 0.5 PPM.
    wolfy's Avatar
    May 2012
    Randleman, North Carolina
    33
    I just received my K-2006 test kit. I am trying to figure out what combined chlorine 1 drop = 0.2 or 0.5 PPM. means.
    Instructions say note: for 1 drop = 0.2, use 5ml sample. For 1 drop = .05, use 10 ml sample.
    16x48 Intex Ultra frame pool with swg
    Mar 2012
    Amarillo, Texas
    341
    Re: combined chlorine 1 drop = 0.2 or 0.5 PPM.
    Use the 10 ml sample. No need to be that specific on a home pool.
    18'x48" AG
    Pentair 1 1/2 HP Dynamo Pump
    Sand Dollar Sand Filter w/ Zeobrite
    Lil Shark Vacuum System
    Hard Plumbed
    38,290
    Those do not look like the correct instructions or you typed something wrong. If you use 10ml of water, each drop for both the FC and CC is 0.5ppm. If you use 25ml water sample, each drop is 0.2ppm
    Chlorine (Free, Combined) Test
    1. Rinse and fill large comparator tube to desired mark
    with water to be tested.
    NOTE: For 1 drop = 0.2 ppm, use 25 mL sample.
    For 1 drop = 0.5 ppm, use 10 mL sample.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    jbliz is right. He cut and pasted from Taylor's site. Your instructions seem to be wrong.
    Mar 2007
    San Rafael, CA USA
    12,082
    The Taylor website instructions for the K-2006 say:
    which is correct. Not sure where the OP got his instructions.
