Thread: Got the green stuff...
    restoman's Avatar
    Dec 2010
    Murrieta, CA 92563
    97
    ...but it's not too bad. YET! I want to nip it, but I may have screwed up. I looked at the control panel Sunday and it said my salt was at 2200. I thought that was low, so I added 4 bags of salt. I know, I know. I now realize that was WAY too much because the control panel says "High salt" and I can actually taste salt in the water! So now I'm draining the pool to approx half way so I can start over again, but I'm not sure I'm doing it right!
    I have Hayward plumbing with an Aqua Rite Electronic Chlorine Generator on my system (Pentair Intellitouch System i5). There's a spigot right before the input to the 4 large filters in the filter tower (sorry if I use the wrong terminology, but I have NO clue what I'm doing). Anyway, there's a tag on it that says "reclaimed, recycled water. Do not drink". I've got a hose hooked up to that and the pool is draining to the street. I also have the filter pump turned on and the vacuum is moving around the pool like normal, and the jacuzzi is spilling into the pool. I turned off the water supply valve so no more water will go into the pool, so I think I have it right?
    All comments will be MORE than welcome by the way.
    Ed
    1) Pool built 2005, approx 17k gallons (Click HERE for a picture of this money pit!)
    2) Equipment: Pentair Intelli-Touch System i5, Pentair MiniMax NTLN Model 400DV Heater, Pentair CCP520 4 Cartridge filter, Aqua Rite 6D22 Chlorine Generator, Turbo-Cell T-Cell-15
    3) Pumps: Pool - Pentair Whisperflow WFE-8 (2 HP), Spa - Pentair Whisperflow WFE-6 (1.5 HP), Water Fall - Pentair Whisperflow WFE-3 (.75 HP), Vacuum: Hayward Navigator 925C
    Aug 2010
    Dallas, TX
    4,052
    Re: Got the green stuff...
    Amazing how different people are when it comes to salt taste. I could taste mine at 1500ppm.
    x2rider's Avatar
    Jun 2011
    Bartlesville, OK
    212
    We had a kid tell us ours tasted like sweat, lol
    27000 gal 18x36 rectangle In-Ground built in 1978
    Vinyl liner, 3/4hp Hayward Super pump, single speed 3450rpm
    SWG: Hayward Aquarite AQR15
    Sand Filter: 300 pound sta-rite T-240BP-1, 3.14 sqft surface area
    K-2006 Test kit
    restoman's Avatar
    Dec 2010
    Murrieta, CA 92563
    97
    Ok, I've gotten rid of the algea and it seems I'm pretty good on with the readings, but here's what I have as of today so any comments would be welcome.
    Total Chlorine ---- 1.0 (min 1.0 - max 3.0) within specs, but seems a little low to me
    Free Chlorine ----- 1.0 (min 1.0 - max 3.0) within specs, but again, seems a little low to me
    pH --------------- 8.4 (min 7.2 - max 7.6) I've added 1 gallon of muriatic acid to bring this down a little
    Total alkalinity ---- 90 (min 80 - max 120) looks good
    Calcium hardness - 325 (min 200 - max 400) looks good
    Stabilizer --------- 30 (min 30 - max 100) within specs, but is this too low?
    Salt ------------ 3000 (min 2800 - max 3200) looks good
    So going by the above, should I do anything about the chlorine and the stabilizer?
    Ed
    Apr 2012
    SW Ohio
    456
    Seems like your cya is low for a swg pool it should be around 70 I think, also your fc is low for your cya.....go look at the chlorine/ cya chart for swg pools in pool school....Mike
    18x52 intex ultra frame pool 6981 gallons, 1 HP LL pump with 19 in sand filter,BBB method,borax 50ppm
    leslies DPD test kit + fas-dpd chlorine test kit + borates test strips
    thru wall skimmer,hard plumbed with 2 returns 1 1/2 sch 40 pvc
    1 large fountain 1 inch sch 40 pvc,shut off ball valves on all
    Apr 2012
    SW Ohio
    456
    Cya should be between. 60 to 80 ppm
    Min fc level 3 ppm
    Target fc level 5 ppm
