Page 1 of 4 1234 LastLast
Results 1 to 20 of 77
Thread: Homemade PVC Solar Cover Hanger's
    Jan 2010
    Randleman,NC
    620
    Well,seen another post on using PVC..Well,I decided to try&pc. some together..I have made mine to just hang over top rail..Work great..Just made them a little to long..Going to shorten them up a little.First go around&turn out very well.Will post picture soon.Had $40 in material using 1in pvc."Thicker wall"..Believe will hold up good.
    Leasure bay AG 24ft,52 in high.installed June of 1999. Hayworth S-180 T sand filter/Power-Flo Matrix 1horse 2 speed pump /Aqua Trol SWG/Using TF-100 Test Kit
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Homemade PVC Solar Cover Hanger's
    Sounds good, but it would be nice to see a picture or two
    Jan 2010
    Randleman,NC
    620
    Got them back on this evening..Got some 1/2 pvc to make a tray in the bottom to saddle the cover instead of just hanging.Gota make another trip to lowe's to get a couple thing's to finish up..I'm very impressed..Just a brain fart&no exact measurement's ,just all by eye.
    Jan 2010
    Randleman,NC
    620
    Project is done!!!Here some picture's..I just put this together by eye..
    poolgranny's Avatar
    May 2012
    Mid-Missouri
    120
    Looks good. Thanks for the pics. I might try something like this. We have a solar cover but seldom use it due to it being hard to manage and the problem of where to put it when we take it off.
    Above Ground Pool 15' by 30' Older pool -- Make ? Model ? Cost - Free; Given to Us
    Gallons approximately 11,000 (if I figured correctly)
    New liner in 2007 when pool was moved and installed by son-in-law and family members
    Hayward Sand Filter 150 pounds of sand (purchased new in 2007)
    White River 2 horsepower pump (purchased new in 2012)
    Deck built in 2011
    Bioguard 1200V Multi-Test Kit with an additional Orthotolidine Chlorine Test Kit
    Jan 2010
    Randleman,NC
    620
    Alway's used a cover since having the pool..Alway's hated taking off&on.But,the benefit's of having one out weigh's the ugg of handling.My pool is old&can't find part's for it no-more so I didn't want to drill any hole's in it..So I figured if I can make them to slip over top rail would be the way..It all come's back apart .The sadle's are glue'd..The bottom 1/2 in. pvc are not glued ..Used tie-strap's to put them together.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    I really like you design, especially the fact that you do not need to "permanently attach" it too the pool. One thought, could you move the part that is pushing on the metal pool wall, so that it pushes on a vertical instead?
    Jan 2010
    Randleman,NC
    620
    Quote Originally Posted by linen
    Thank's.I thought the samething..But,it's not putting any pressure on the wall.I will keep a eye on it...Surprising that there is no pressure to the wall.The weight is on on the the top rail.The top of the sadles are a tight fit&are held in place on each side of the lip.Take's a little force to get them off&on.
    Glock's Avatar
    Jun 2012
    Mesquite, Texas
    866
    I am going to make this for my pool once it is installed. I really like the idea. Going to make a float holder too. Yours looks really good.
    18x34 Doughboy AGP 22300K Gallons - Build Thread
    Aquaview 24" Sand Filter - 1.5 HP Powerline Pump - Barracuda Ranger - Taylor K-2006 - BBB
    Pool School and Pool Calculator
    Jan 2010
    Randleman,NC
    620
    Quote Originally Posted by Glock
    Thank You...
    Apr 2012
    Rockland County, NY
    9
    Looks great. Do you have any measurements? I know some will be specific to my coping and pool but just looking for more info on what you did.
    24' Round AG, 54" wall height, 22" sand filter
    1 1/2 HP pump, 104 BTU Hayward Heat Pump
    Rockland County, NY
    Jan 2010
    Randleman,NC
    620
    Quote Originally Posted by ericjr7210
    No measurement's.Just did the first one by eye & made the other two off of it..I first made them to long&had to shorten them up..Work's great so far.
    nelson411's Avatar
    Aug 2011
    Northern California
    163
    The saddles are great! I'm going to borrow your design! We have an Intex Ultra Frame, and the cover is so unmanageable. I just logged in to search for this kind of mod.
    thanks for posting the pictures!
    Northern California Inground pool 14' by 30'
    Diamond Brite Quartz Medium Grey Plaster - Islands Sapphire Breeze Tile Border
    Jules Bright Cobalt Blue Blend Tile Bench fountain sheer waterfall descent
    Pentair Intelliflo Variable Speed Pump - Pentair CLean & CLear PLus Cartridge Filter - Kreepy Krauly Legend - mTF-100 Test Kit - Swimmers: Twins (Boy/Girl) 16 yrs old
    I took a simple route and folded mine in half, rolled it inside a tarp and used rope and bungee cords to hang it from the fence. It's ugly, but I had it covered with the tarp laying on the ground. (which was even worse)
    Aaron
    [ Vogue Vectra 24' AG | Hard plumb: Hayward Power-Flo Matrix 1HP 2-speed, 27" sand filter & Pentair MiniMax 100 NG | Taylor K-2006 | Central IL ]
    Powered by: TFP, PoolMath & TFTestkits
    Jan 2010
    Randleman,NC
    620
    Quote Originally Posted by nelson411
    They are still holding up.So nice.Wish I had did that alot earlier.
    Jan 2010
    Randleman,NC
    620
    Well they are still holding up perfect.No dent's or concern's about them resting on the wall..
    PAGirl's Avatar
    Jun 2012
    Central PA
    2,388
    I have often wondered if much of the sediment on the bottom of my pool is coming from the cover being thrown beside the pool. This looks like a great solution, I might even try to do it myself!
    Jun 2012
    West Michigan
    7
    What a fantastic, inexpensive idea!
    Thanks for posting this - I'm going to have to try a version of this.
    I love my solar cover, it helps keep my temp higher during these cool summer nights.
    I cut my cover in half and it's so much more manageable.
    When I put it back on, I just make sure to overlap the 2 pieces - hasn't moved or blown in the least.
    24'x52" Opus w/ Portofino J hook liner
    Ecco sand filter w/1.5 hp pump
    Half deck (wood) with Biltmore pool steps
    Barracuda 1500 vacuum
    Rheem Digital Gas Pool Heater Model #266 - 266,000 BTUH
    The design of the posted pictures is dangerous. 1. makes a great laddeer for kids to climb in pool. 2. push down on the top pipe far fron the pool and you cave in the pool. The original is looking beter to me
    22.6K gal, 20'x40', w spa freeform white plaster Sylvan 2011 pool. Rheem Raypak 400K Digital NG heater, Jandy PlusHP 2.0 pump, Jandy 48sqft DE filter
  20. Back To Top    #20
    redhdgirl417's Avatar
    Sep 2012
    Mid-Michigan
    127
    I bought the Solar Saddle last year for our new pool and just love it...keeps the cover nice and clean and no problems putting it back on the pool or taking it off by myself. Great job designing your own!
    13,900gal 24'x52" Backyard Leisure Heritage AGP
    20ml All Swirl Flat Liner
    Pentair 1.5hp Pump and 150# Sand Filter System
    Smart Step Ladder w/Smart Light
    TF100 test kit, BBB Baby!
