Thread: Four days after opening...
    Apr 2008
    Started the opening off with a really nasty looking bottom. Added one of the big jugs of bleach on the first day and started the vac....
    Gotta love how the previous owner closed it down. Yes, that is the ladder on the right that stayed in all winter...
    Hmmph ... looks like I need a new one of these.....
    Nice layer of green goop.
    And now just 4 days later, the water is clear and the bottom isn't gross..
    10,600 Gallon 12x32x4 Above Ground
    Hayward Veri-Flo sand filter
    Hayward 1hp pump
    Taylor k-2006
    Butterfly's Avatar
    South Carolina
    What a transformation and in only FOUR days, too!
    The pix are great.
    You're done SLAMing when:
    Richardson, TX
    WOW! I'm truly impressed!
    Great job and nice pic's too!
    My pool works thanks to TFP
    Please support the site! pages/supporters/
    It's cheaper than your first trip to the pool store!
    I had a similar experience with my pool last week. My pump died a week before I closed the pool last year, so I never really go it cleaned out when I closed it. I also had a new winter cover that allowed water to drain into the pool during the winter through some very fine mesh in two panels. When I opened it the pool for the first time was not crystal clear. I could barely see the bottom in the deep end, and there were lots of leaves in there too. Four gallons of bleach, lots of cycles with my Blue Pearl and three days of filtering and she is crystal clear and ready for a swim.
    20x40 IG vinyl, heatpump and solar and 3 siberian huskies, 10kw PV solar electric system. Nikon Photographer D800e dSLR.
