Results 1 to 17 of 17
Thread: Deck jet install
    Deck jet install
    I am looking at installing deck jets during a new build and had a few Questions.
    1. From reading the instructions for installation it says 1 1/2 pipe is recommended with 4 jets but it has to be reduced to 3/4 at the jet. I am doing a loop, should the loop be 1 1/2 or 3/4? I was thinking 1 1/2 with a 3/4 tee at each jet
    2. Do these lines need to be buried or can they be set on top of the ground around the pool and concrete be poured over the top of them?
    3. If concrete is being poured 4" thick should I have the PVC come up 6-7 inches and when the concrete dries cut it down flush with the deck then glue the jet to the PVC?
    18x36 Grecian Vinyl; 8' Roman steps w/t 2 spa jets; cozy cove w/t 6 spa jets; 2 MD, 1 Skimmer, 3 returns; Hayward Ecostar, 30" Ranger sand filter; Hayward color logic 4.0 LED light; Hayward aqua logic; 2" PVC pipe 4 Jandy Valves
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: Deck jet install
    I can't comment on 1 or 3, but you definitely don't want to put the pipes in the concrete. Concrete always cracks and shifts, and if the pipes are embedded the cracking will destroy the pipes.
    Deck jet install
    So what around 4-6 inches below or would they be better down with the rest of the plumbing and just run it up through the backfill?
    Oct 2009
    3,899
    Whatever's easier!
    Columbus Ohio
    178
    I have 4 deck jets my self. They are installed into the concrete and have had no issues with them. I do recommend putting only 2 on each run of pipe. When you do more than 2- they all seem to get different amounts of pressure. Also, having 2 valves at the pad makes it much easier to adjust hight.
    Purposed new pool at home being built- 20x40 vinyl pool, 20ft vinyl covered steps, Automatic cover, 6 ft sheer decent, 4 lighted deck jets, lime stone coping, easy touch, heat pump, SPA- 8x8 fiberglass shell, limestone steps surrounding
    previous home- 16 x 32 IG Vinyl- Install- Mid June 2011. 3ft Shallow 8ft Deep/ Totally Hayward 1HP pump/ 250 pound Sand/ AquaPro800 Heat pump/ Blue Hampton Liner/ 2 Intellibrite LED Lights/ Polaris 360/ 4 Deckjet II's/ 3ft concrete Apron/ 800 sq ft Paver Patio
    Deck jet install
    Quote Originally Posted by tatertot09
    Did you install them? I am really wondering about the PVC that connects to the deck jet assembly. I would imagine you leave so much poked out of the ground, pour concrete and when the concrete cures just cut it flush but have not been able to verify that.
    Nov 2011
    Moberly,MO
    1,010
    Bury the loop on top of your bond beam at the base of the wall. Plumb to the bottom of the jet housing and set it to the grade of your concrete BEFORE the deck is poured. If you run them off of a continuous loop they should maintain a pretty even height
    Over 30 years in the pool business
    We build vinyl, fiberglass, stainless steel pools
    Certified in Hydraulics
    Deck jet install
    Quote Originally Posted by swimcmp
    Ok thanks for the help. When would you reduce down to 3/4? The whole loop or just the part that goes up and attaches to the jet?
    Nov 2011
    Moberly,MO
    1,010
    Put a 1 1/2" T under where you want your jet then bush down to 3/4" on the top of the T to the jets
    Deck jet install
    That's what I thought. Appreciate your help!
    Deck jet install
    Is there any difference in the pentair magic jet 2 and the jandy deck jets? Just a matter of preference it looks like.
    Nov 2011
    Moberly,MO
    1,010
    Might be some price difference not familiar with jandy so can't answer that
    Apr 2009
    DFW Area
    13
    Hopefully, this thread is still alive... I am getting ready to build my own pool (owner-builder), and in talking with the plumbing contractor, he said he preferred to run a separate 3/4" line for each deck jet, as he says it is difficult to get the jets adjusted evenly even when they are run on a loop. The pool we are building rises out of the ground ~10-12", and has no decking. Instead we are installing 30" square paver pads with 3-4" of grass in between the pavers and between the pool and the pavers. As such, we want to install the deck jets in the bond beam. Is this an acceptable practice? I assume that PVC will be run on the outside of the bond beam, then run up through the bond beam where each jet will go? Thoughts / advice appreciated. If this is not an acceptable practice, we could just install Pentair aerators on the inside of the bond beam, but I have not seen these in action, so probably prefer the deck jets.
    Bobj.
    19,000 IG Pacific Blue plaster,raised spa with spillover,rock waterfall, Jandy 2.5 HP pump,Pentair sand filter,Paramount in floor cleaning system, Jandy Aquapure SWG, Aqualink remote
    Nov 2011
    Moberly,MO
    1,010
    I would recommend that the source for the jet be buried on top of the bond beam not in it. This will allow the jet some movement without stressing the pipe if it was in the bond beam
    Apr 2009
    DFW Area
    13
    Thanks Swimcmp. If I understand you correctly, I think you are assuming the bond beam will be under coping that is flush with the deck, and the plumbing should then be placed on top of the bond beam, but below the coping? If this is correct, it sounds like the deck jets might not work out or I will have to find a way to mount them in the ground. We will have a raised bond beam around ~1/2 the pool, due to the negative slope in the yard (as high as 12" out of the ground on the back side). We have considered building a retaining wall so we can backfill against the pool wall (raise the yard) so that the coping is ~2" above ground level, but we will still have no deck, in the normal sense of concrete up to the edge of the coping. We will basically have grass next to the pool, with concrete stepping stones around the pool and grass borders between each stepping stone (~18" x 24" rectangular pads). I am assuming the pads will not be stable enough to mount deck jets in (think of them as really big pavers on top of gravel bed), so I was hoping I could mount the deck jets in the bond beam. Wasn't sure if this was an acceptable practice as the plumbing might make too bid a void in the bond beam. Based on you recommending an approach to keep the plumbing out of the bond beam, I am guessing this running the plumbing in the bond beam is a bad idea?
    Thanks
    bobj.
    Nov 2011
    Moberly,MO
    1,010
    I take it you are building a gunite pool? If so you wont be able to put the loop plumbing on top of the bond beam. I dont recommend putting any plumbing into any form of concrete.
    Apr 2009
    DFW Area
    13
    Yes, we are building a gunite pool. Looks like we may need to install some minimal decking in order to get these installed correctly. Not what I was hoping for, but I want this to be done right to minimize problems down the road.
    Bobj.
