Thread: Repairing formerly wood-filled expansion joints
    Hi! We have a long-term lease of a home with a inground vinyl-lined pool that's in disrepair. Landlord has no desire to fix or maintain the pool, but was agreeable to our fixing. We are having a pro install the liner, but we are doing repairs to the decking, landscaping, etc. We are trying to do this work as inexpensively as possible, because we'll only be using the pool for 5 or 6 years.
    The pool was built sometime in the 90s and has concrete decking with those little brown rocks embedded in it. Every five feet or so, there's an expansion joint with a 2x4 set in it. The joints radiate out from the pool coping to flowerbeds/landscaping that surrounds the concrete decking. (Maybe these aren't properly called expansion joints, because they seem to be wider and depper than is typical?) Anyway, these boards were in varying states of rot, and some were completely gone and the 2 inch wide by 4 inch deep joints were packed with mud, leaves, pine needles, gravel, etc.
    I've attached a couple pictures of the cleaned-out joints.
    Our intention was to clean these out and replace with new treated lumber, because that seemed like the easiest fix. Just have Lowe's cut them to length and pop 'em in. Of course, when we got them cleaned out, though, we saw that each boards would have to have at least 3 notches in the bottom of it to accomodate rebar that runs across the joints and a piece of what looks like metal framing that runs around the pool a couple of inches below the concrete. We bought a 2x6 and notched it and tried to place it in the joint. Notching was no big deal, but it looks like the concrete has shifted a bit, and the joint is now too narrow to fit a 2x4. More than half of the joints are this way. (There are 19 joints, totalling about 144 linear feet.) So these boards would have to be planed. We don't have the tools for that, so we'd have to hire a carpenter to do it.
    So I searched this forum, and saw the advice regarding using sand to fill the joint, then topping with a self-leveling sealant like Sikaflex. I thought I had the answer until we noticed that the ends of the joints are open to the pool coping and there are little gaps in the coping that would allow sand to run into the pool. (Doesn't look like there's anything wrong with the coping -- it's just not made to be water tight.) It looks like water from normal pool use would just wash the sand into the pool, and we've have a mess in the pool and the sealant would crack/break/fall. To make it work, we'd have to have something on each to cap the joint and hold the sand. Maybe quickcrete or some type of solid cap? We don't really know what are options would be, and this is starting to get complicated.
    I'm looking for advice. Should we stick with the board idea and just get a carpenter to help us, or is there a way to make the sand and Sikaflex approach work? Or is there another fix that we haven't considered? The liner will be installed this week, and I'd really like to get this done before the pool is filled.
    Kristen
    [attachment=0:3b4rdnpy]pool joint distance.JPG[/attachment:3b4rdnpy][attachment=0]
    harleysilo's Avatar
    Mar 2012
    North Georgia
    1,924
    Re: Repairing formerly wood-filled expansion joints
    I think i would replace the wood as it was originally designed. You can buy for pretty cheap a hand planer http://www.homedepot.com/webapp/catalog ... 5yc1vZc27y
    This won't be as accurate as say a planer that you feed the board through, you'll have to make two passes to plane a 2x4 or 2x6, but you also don't need it to be perfect. You've already figured out how to make the notches (you can use a cheap hand saw to make two notches/cuts, and then a chisel to cut the chuck of wood out, again it doesn't have to be perfect.
    Lot cheaper than hiring a carpenter i'm betting.
    Edit: You may be able to rent a real planer at a home improvement store....faster and easier.
    18'x43' Sport Pool
    19,000 Gallons Vinyl Liner 3'-3.5'-4'
    SWCG and D.E. Filter
    Test Kits - Pool Calculator - Chlorine/CYA Chart - Pool School
    Secret Weapon for Pool Chemistry Testing
    Hadn't even considered buying a cheap planer or renting. Duh.
    You're right. It seems like we need something solid in there or else we're going to get tons of **** washing into the pool.
    I'll check out buying/renting. Thanks!!
    harleysilo's Avatar
    Mar 2012
    North Georgia
    1,924
    It's just a really big gap, one i wouldn't want to try and caulk. Plus the wood wood look purty....
    18'x43' Sport Pool
    I agree. It sure looked nice when we sat it on top of the groove -- before my husband beat it to smithereens trying to get it into the groove!
    22,553
    If you don't need to take too much off the 2x4's you can also use a belt sander to do it. Planers can be a little harder to handle than a belt sander.
