Results 1 to 10 of 10
Thread: When should algecide be used?
    We are still in the process of converting from Baquacil to chlorine, but just wondering about something. In reading all about the BBB method and going back to chlorine, when is it appropriate to use algecide? When purchasing chlorine at the big box store, I picked up some HTH algecide which is supposed to last 90 days (thought that sounded like a good thing), but after reading it appears the suggested method would be to just shock instead of using algecide. So should algecide be used preventatively, only when algae is visible, or not at all-shock instead?
    21 x 41 above ground, vinyl, with deep end; 28,000 gallons; AquaView 24" sand filter, 2 hp pump,
    Re: When should algecide be used?
    The only times we recommend using algaecide are during an AA treatment and when winterizing the pool.
    By the by algaecide is never particularly effective when you have an algae bloom in progress.
    Jul 2012
    CA
    240
    Pool guy said i need a yearly algecide treatment today, i got one last year and i didnt have any problems, should i continue? what shouldbe a reasonable price for this?
    25k I/G ecostar ccplus Polaris plaster
    38,395
    Like Jason said before, rarely needed. If you keep the FC in the appropriate range for your CYA level, you should not get algae.
    Btw, certainly never use any with copper in it.
    Posted from my Droid with Tapatalk ... sorry if my response is short
    Jul 2012
    CA
    240
    Ok, so its just a way to make some more money. thanks
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    tablpa:
    The only other time when using an algaecide could be justified is when you are out of town for the better part of a week or more and the pool will be unattended. It will provide a little bit of insurance against an algae bloom should the FC drop a bit below the recommended range for your CYA. In this case, the algaecide buys you a little bit of extra time - it is not a license to let your FC stay below the recommended range for an extended period. The recommended algaecide is a Polyquat 60 formulation.
    As others have stated, an algaecide is not needed in normal day-to-day maintenance when the FC is kept at the recommended range nor will an algaecide be of any value once an algae bloom has started. In that case, the shock process is the way to get rid of it.
    cood60's Avatar
    Jan 2012
    Virginia Beach
    82
    I have been having a tan dusty debri that collects in the seams etc
    The folks that installed the pool keep telling me it is algae dead or alive and is too small to filter
    OCLT is successful though, so I doubt that it can be algae. (I have been vacing to waste ad nausium)
    The guy at the local pool company tells me that there are other things that can consume chlorine other than sunlight and algae. Is this true?
    I keep thinking it is dust from the mines that produced the ZeoLite product I use for sand media.
    WIll using an algaeside (polymeric) cause me to "need" it's continued use? I was thinking of doing one algaeside treatment just to rule out algae
    Any ideas?
    22'x40' IG, Freeform, 26K gal, Vinyl liner pool(2011), three returns plus two step jets, one slide, two skimmers, two LED lights, Stamped Concrete with Aqua PL-Plus Automation panel, Pentair Intelliflo VS, Hayward Pro Series High Rate Sand Filter 500lb, Hayward Turbo Cell T-Cell 15 (SWG) , Dolphin Robotic Pool Vac, Hayward Heat Pump.
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    The better way to rule out algae is to raise your FC to shock level for about 24 hours and then hold it about 5 points higher than normal for a couple of weeks. If algae is growing, the algaecide will have little effect on it.
    If that doesn't make a difference, run your pump 24 hours a day for a while and see if it improves.
    Most anything biological will consume chlorine, and that includes waste from swimmers.
    cood60's Avatar
    Jan 2012
    Virginia Beach
    82
    Thanks, I will give it a shot
    I forgot post my stats including cool water temp
    Water temp is below 50, should it not be impossible to have live algae in cool water?
    SW Indiana
    9,199
    Quote Originally Posted by cood60
    Less likely. I'd increase your high-speed running hours. I live in farm country and get a lot of dust in my pool. If I run the pump 8 hours a day the pool stays dirty, but 10 or 12 hours helps quite a bit.
