Thread: How to fill hole in steps?
    Shpigford's Avatar
    Apr 2011
    Birmingham, AL
    50
    We've got an older in-ground pool (guessing put in sometime in the early 90's) and the main steps into the pool seem to be getting a little brittle.
    The other day I noticed a hole about the size of a dime that I'm guessing is now leaking water, so I'm curious...what do I use to fill that hole?
    I assume the steps are fiberglass and I'd say the hole is about 8-10 inches under water.
    22,000 gallon vinyl in ground with Hayward S244T sand filter and Hayward 3/4 hp Super Pump.
    May 2009
    Marion, Ohio
    32
    Re: How to fill hole in steps?
    My hubby used a fiberglass repair kit in the automotive section at local hardware store - fixed the steps good - but now need to find good underwater paint for it. Anyone have suggestions for painting after the fix?
    10,000 gallon inground vinyl FOXX pool - built in 1999. Hayward sand filter. 3/4 HP 2-speed pump with timer. Hayward Aquarite SWG t-3 cell. Love the BBB method - pool has never looked better!
