Thread: Solar Cover, Heater and Pump
    Mar 2008
    Indiana
    28
    Since this is my first pool and I don't know any better...Can I run my heater and pump while the solar cover is on?
    20x12X4 Oval Fiberglass walls and concrete bottom.
    Pool is in an unconditioned atrium. (being remodeled)
    3/4 HP Hayward Pro Pump. Tankless Water Heater.
    Hayward S180T Sand Filter.
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Yes. Best to remove it at least every few days for out gassing and to let the skimmers work.
    NJ
    291
    If you have the cover on there really is no need to let the skimmers work as there is nothing getting in the water - it is falling onto the cover.
    I have operated my pool for 10 years with the pump running and the solar cover on -- and only take it off when someone wants to swim with no problems.
    20x40 IG vinyl, heatpump and solar and 3 siberian huskies, 10kw PV solar electric system. Nikon Photographer D800e dSLR.
    I also run my pump (and heat pump on my last pool) with the solar cover on. I usually close the skimmer and pump from the drain to circulate the the coldest water from bottom out the returns to the top in order to warm the pool a little faster.
    Mar 2008
    Central VA
    328
    Great idea! I run my heat pump with a solar cover on, as well, but have been frustrated (last season, haven't run it yet this season) with the s-l-o-w rate at which my temp. would come up. Maybe closing the skimmers will help this year...
    Todd
    Pool: 16x36, 16,800 gal., vinyl, sand filter, SWG & AquaCal Heat Pump
    Spa: Hot Springs Sovereign, 355 gal., ozone/ion
    The most helpful tool you'll ever have for your pool:
    http://www.poolcalculator.com/
