Results 1 to 10 of 10
Thread: Outdoor Stereo/Speaker wireless setup -- Suggestions please!
    Looking to set up an outdoor, wireless stereo with speakers (that have great sound) for my pool. I want to be able to use the playlist off my iphone and use the iphone as a remote. Does anyone have suggestions? I saw something for sale on Frontgate, but not sure the quality level (gets good reviews) but really looking for great sound from the speakers. Thanks for any help with this!!
    Jun 2010
    Dripping Springs, TX
    125
    Re: Outdoor Stereo/Speaker wireless setup -- Suggestions ple
    I use the Sonos system and it is fantastic.
    One component (Sonos Bridge) connects to your wireless router/hub via Ethernet cable.
    It then broadcasts the signal to your other Sonos components. They make "boombox" style, portable units that have nice sound, and they just came out with a wireless subwoofer. None of this gear is
    rated for outside, so keep that in mind. Your iphone/ipad is your remote control and integrates with Pandora, MOG, etc.. It not only controls your playlists, it is also your volume control. You can have multiple Sonos zones that will all sync up and play together, or separately if you want. It also streams music off of your network attached storage, so essentially where the music is being sourced from becomes transparent to you. You can even make a playlist that mixes songs from MOG and your own hard drive.
    I am using a basic receiver to drive 4 outdoor wired speakers. Sonos makes a component that plugs into this receiver outside by the pool, so this component communicates wirelessly to the Sonos bridge, but I get to use my own amplification and speakers (superior fidelity).
    There is a also a system called Squeezebox (I think Logitech may market this) that I've heard good reviews about. Sonos is more expensive, but I have to say the quality is great and
    it's brain dead easy to set up.
    SF
    17K gallon IG freeform Pebble-Tec pool w/ raised spa/waterfall, Hayward 6020 DE filter, Tristar 1 HP circulation pump, Tristar 2.5 HP spa pump, Silencer 2hp blower, Aquarite SWG, Polaris 280 w/ booster pump, Hayward Universal H-Series 400K LPG heater, Ultrapure Ozonator 25, Aqualogic PS-8
    May 2011
    Orange County, CA
    696
    I have a couple of Squeezebox Duets that do a similar job as the Sonos. I think the Sonos units are a little more user friendly, but the Squeezebox is now running quite nicely. I can control it either using the Squeezebox remote or with my Android (or an iPhone) using Logitech's app for this. It's pretty sweet.
    38K in ground pool with attached spa. Current equipment: Easytouch 8 (521150) with IC-60 SWCG with web control by Autelis, 1x Pentair IntelliFlo 011018 pump (for filter), 1x Pentair 2HP WhisperFlo pump (for waterfall), 2X Pentair IntelliBrite 5G 12V lights, Pentair MiniMax400 NG Heater, Pentair SMBW2060 DE filter. Zodiac Barracuda MX8 cleaner on dedicated cleaner line. Lighting/home automation controlled by Insteon/ISY-99i.
    gullzway's Avatar
    Nov 2009
    Tulsa,OK
    103
    Quote Originally Posted by CraigMW
    Will these play music directly from your android phone? I was looking at these types as well as Bluetooth speakers. I want to be able to stream directly from my GS2 android phone to the speakers.
    17,500 gallon 18x36 gunite pool
    Hayward super II 1.5 hp pump, Hayward cartridge filter
    Jandy AquaPure Ei SWG 35K, Raypak R6350TI-E HeatPump
    Solar cover, Loop Lok winter Cover
    Artisian Antigua hot tub, Polk Atrium 4's
    May 2011
    Orange County, CA
    696
    Quote Originally Posted by gullzway
    I'm not sure about that, as I usually listen to either Pandora or my own iTunes library hosted on my PC. There are a number of Android apps that are great for Squeezebox, esp. the free one from Logitech that allows you to control your Squeezebox player(s) via WiFi. There is an app called SqueezeCommander that may provide this. Basically, it would need to support a program called SqueezeServer on the Android itself. That being said, while it's probably doable, it would simply kill your battery life on your Android because of all the WiFi transmission. So, while it's a nifty idea, it would probably be more practical to just sync your Android occasionally with your PC and have the PC (running SqueezeServer) to act as your music server. You can still control which songs you want to listen to with your Android, but not have the Android's power sucked out of it.
    BTW, on my Android, I have my Squeezebox Controller (remote control) and also a program to control all of my Insteon based lights, etc. It's cool to be able to sit down in the yard and control not just the music, but also the lighting in the house and yard. Soon, I will also be able to control the various pool functions from my Android as well (via EasyTouch and Autelis). I really think you don't realize the power of smart phones until you get this sort of functionality.
    elwood58's Avatar
    May 2012
    Sun City West Arizona (2nd Home)
    653
    We bought this speaker from Walmart for $59. It will pair up to your phone without using the dock. Disregard the typo referring to it as a Sprinkler, it is a Speaker. Even has lights build in. Sound is very good.
    http://www.walmart.com/ip/Goodtimes-Orb ... r/20896256
    19204 Gallon L Shape with a 10X10 2nd Step Baja Ledge. Intellichlor IC-40, IntellipH, Cartridge Filter, Pentair Heater/Chiller (Heat Pump). Tons of Deck with Deck Jets. Construction Complete 6/5/17.
    "If you don't measure it, you can't manage it!"
    Jul 2011
    NY
    51
    Is there specific music on your phone that you want to play or are you using a music service on your phone ? If the later, Sonos has the built-in ability to play Internet Radio stations (there are thousands available), Spotify, Rhapsody, Pandora (which is excellent and free). All without draining your phone battery.
    To tell you the truth we very rarely play the 50k tracks we have ripped anymore. We mostly use Pandora and Spotify, and local Internet Radio of course.
    29,700 Gallon Vinyl Roman End, Sta-Rite Max-Therm-400HD gas heater, Sta-Rite S7M120 cartridge filter, Pool Pilot DIG-220 SWG
    May 2011
    Orange County, CA
    696
    Yeah, same for the Squeezebox. It also plays all of the above... I just listen to Pandora. Good music with great selections and sounds awesome.
    We got one of these last Christmas. Kind of pricey, but it has Aux and Bluetooth hook ups to use it with many kinds of devices. We usually just hook up to our Android phones via bluetooth and use either Pandora or our playlists. We can play, pause, skip the music and control the volume right through our phones. It's not huge sound, but it still fills the backyard very nicely. Best part, it's very portable. You can put it where ever you want and take it with you pretty much where ever you go. Battery life has been very good so far as well. I've never been a huge fan of Bose, but this has won me over.
    http://www.bestbuy.com/site/Bose%26%...&skuId=2989098
    28,350 Gallon
    IG Rectangular Vinyl Lined
    1 skimmer and 2 returns.
    Pentair SuperFlo 1 HP Pump
    Pentair Vertical Grid D.E. Filter
    Pentair 250,000 BTU Natural Gas Heater
    this just arrived at my office! awesome sound and easy to use! http://www.logitech.com/en-us/speakers- ... ombox-ipad
    Southeast Georgia
    IG 27,000 gallons w/ flow over spa
    Diamond Brite
    74 gpm Sand Filter
    2HP Pump
