Page 1 of 3 123 LastLast
Results 1 to 20 of 45
Thread: cheap pool lighting
    Apr 2012
    SW Ohio
    456
    cheap pool lighting
    i was at wally world the other day and i seen they had these L.E.D pool lights that connect with magnets and operate on 3 aa batteries w/remote so i though for 10 dollars i would give them a try and to my surprise there were 2 in the box thats right 2 lights w/1 remote for 10 dollars and they have a high and low setting. i was thinking hmmmm how lame can these be but to my surprise they work great they put out the right amount of light and i think are a good deal for us who are on a budget.
    18x52 intex ultra frame pool 6981 gallons, 1 HP LL pump with 19 in sand filter,BBB method,borax 50ppm
    leslies DPD test kit + fas-dpd chlorine test kit + borates test strips
    thru wall skimmer,hard plumbed with 2 returns 1 1/2 sch 40 pvc
    1 large fountain 1 inch sch 40 pvc,shut off ball valves on all
    techguy's Avatar
    Jul 2010
    Antelope, CA
    2,687
    Re: cheap pool lighting
    Could you post a photo of the box and the lights. I might be interested. I saw something like this at Wally this past weekend and it was not priced like what you are talking about. IIRC what I saw was about $60 USD.
    -- Guy --
    I bought the same ones last week and they work great.
    Anne Marie, Monmouth County ,NJ. Salt water in ground french grey quartz/gunite pool 25000 gallons install July 2012
    Apr 2012
    SW Ohio
    456
    here you go
    Sep 2011
    Omaha, NE
    95
    Is there a brand name? model #?, place where you purchased??
    16X24 Oval Doughboy
    10,000 Gallons~
    Pentair Dynamo .75/1.0 HP pump
    16" Pooline D-400 Sand Filter w/ 6-way valve
    Apr 2012
    SW Ohio
    456
    I'll go look and see
    Apr 2012
    SW Ohio
    456
    Goodtimes L.E.D light ....9.92 for 2
    Aug 2011
    Metro Atlanta, Georgia
    161
    Quote Originally Posted by fast1971chevelle
    Thanks, this one? http://www.walmart.com/ip/Goodtimes-LED ... e/20896253
    How fast is "fast"?
    My cement pond is a 36K gunite 20X40 built in mid 1960s, Hayward S244S filter, Aquarite SWCG, Jandy 1.5HP 2sp, TF-Test kit and Nitro Wall Climber
    Apr 2012
    SW Ohio
    456
    Yep those r the ones.....the box say requires 3 aa batteries....that is false each light takes 3 and the remote takes a round watch battery but it is included.......Mike
    Aug 2011
    Gainesville, fl
    53
    Just bought these today. Work pretty good for 10 bucks. I may actually only use one for my 12ft pool. I may try and modify one to red or blue leds.
    12"x33" Summer Escapes AG Ring Quick set 1590 Gallons (Gift for my son by Grand-parents)
    Intex Krystal Clear Model 633 2500 GPH "B" Cartridge
    How does everyone prefer to mount these? I'm assuming the magnetic part is rounded and smooth as to not damage the liner.
    Aaron
    [ Vogue Vectra 24' AG | Hard plumb: Hayward Power-Flo Matrix 1HP 2-speed, 27" sand filter & Pentair MiniMax 100 NG | Taylor K-2006 | Central IL ]
    Powered by: TFP, PoolMath & TFTestkits
    Aug 2011
    Gainesville, fl
    53
    The magnet is in the light and there is a metal plate that goes on the outside of the pool. It seems pretty flat and non sharp. I plan on testing mine out tonight when it gets really dark to see how bright it is.
    Aug 2011
    Gainesville, fl
    53
    OK for those of you who wanted to know if these are a great light. YES. I have a small pool but one lights up the pool pretty good. And 2 is almost like having day light come through. I will definitely try to modify one of them to use red or blue lights. Possibly will be buying another set to modify them as well.
    Apr 2012
    SW Ohio
    456
    I found out today that you can't leave them in the pool because over time they will get water in them...so take them out at the end of the night and open them up and drain any water out and let them air dry......Mike
    I bought two boxes, but pool doesn't go up til later today. I read somewhere, maybe wallyworld reviews, that some people used pool o-ring lubricant on their o-ring to keep them dryer. Another person placed them inside a Ziploc and then put them in the pool. Hubby brought me some fancy industrial lubricant from work. I'll post back when I see how they do.... waiting for installer as we speak!
    Vogue Vectra 30' Round (21,200 gallons), Waterway 2HP 2-speed, 27" sand filter - TF100 -- Southern IL - Install 06/2012
    Last minute upgrade from 27' due to error in dealer inventory *yikes*
    Jun 2012
    Long Island, NY
    102
    These look pretty neat! Going to check Walmart on the way home.
    Thanks - John
    Pool: Sharkline Matrix 18 Round 54 Deep
    Pool Size: ~8200 Gallons
    Filter Type: Sand
    Pump: Intex 2650
    Samantha_in_AL's Avatar
    Apr 2010
    Altoona, AL
    242
    I bought them a few weeks ago. They worked great for one night until water got into them. I may try again with some O ring lubricant and a ziplock bag. You can't beat the price!
    AG 18' X 52" Round Pacifica Pool w/ Metal Diamond Unibead Liner. Installed in March 2007.
    2.5 HP Baquapure 2 Speed Pump, 200 GPM Waterway ProClean Cartridge Filter System.
    Former Baquacil user
    Converted to BBB in Fall of 2009 - Now I have a truly trouble free pool!
    I bought two sets and found that the magnets aren't strong enough to use, the metal plates zip tied to the ladder doesn't work either since the air inside forces them to float. However! I did get lucky and they fit nicely wedged in the gap on the sides of each step. Didn't notice any water in them. Used for about an hour last night. I'm planning to get 1 more set so I will have 6. 3 on each side (the top step lip won't hold it since the bottom part flips upward).
    The pressure from them wanting to float makes them fit perfectly!
    With 4 last night I could see throughout the entire pool. If I could aim 2 in every direction it would be much brighter, but other than using string to wrap around them and the step I can't find any way to mount it other than wedging under the steps lip.
    Aaron
    Speedo: were you using the metal plate that came with them? I think the Aluminum walls are going to be a problem for us but glad you found a solution that works with the steps! The steps look HUGE sitting in the yard
  20. Back To Top    #20
    Aug 2011
    Virginia Beach
    295
    Mrs.Kid picked these up last night so we got in the pool to try them out. Better than I expected for $10! One lights up our 18x48 Ultra Frame adequately on either dim or bright, the pool seemed well lit with both lights mounted on opposite sides of the pool.
    Word to the wise- the remote is DEFINITELY NOT water resistant at all. I managed to get water in it somehow. It was working last night, this morning I found the indicator LED on it glowing and the button non-responsive. I opened the remote and found condensation inside, so I'm letting it dry out. Hopefully it will start working again. Even if it doesn't, for the price I'm not going to complain.
    Intex Ultra Frame 18' X 48" 7600 +/- gallons
    Columbia 50 LB sand filter/ HP pump, $$ WELL spent(2nd best thing bought for the pool)
    Virginia Beach, VA
    TF100 test kit- Money WELL spent (best thing I've ever bought for the pool)
    Leisure bay hot tub
