Results 1 to 14 of 14
Thread: Water's clear. Don't like what I see.
    Alright, I've got the water dialed in.
    Fc 4.0
    Cc 0
    Ph 7.5
    Cya 30
    Ta 110
    Ch 220-230
    The waters now crystal clear and the bottom and sides of the pool (gunite) are extremely mottled and what looks to be scaled. We're planning on a full remodel next year or the year after. However, we also have a slight leak I still haven't managed to locate other than its not in the plumbing. Could the plaster be totally shot and causing this? I attached a couple pics. Is there anything I can do as it also seems to be getting worse.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Water's clear. Don't like what I see.
    I am not seeing any pics.
    Sorry. I took the pics on my phone and had to shoot them over to the laptop.
    And that's not a reflection. It's ugly looking.
    I'll see if I can can a couple more after dark that show it even better.
    Another pic by the stairs where it's really evident. Check out the sweet white stripe. Totally high end stuff. Can't feel it by touching it though.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    I am no expert on calcium scaling, but it sure looks like it could be to me. Hopefully others will take a look
    Have you read this poolschool article?: http://www.troublefreepool.com/pool-...alcium_scaling
    Was it originally the color of the darker patches and been getting lighter? If so, calcium scaling.
    Or was it originally white and has only recently turned that color? If so, copper stains.
    I'm not sure. I've only owned it for a couple months and looks like it saw some neglect with recent years. It almost looks like the plaster is wearing away. It seemed to darken and wear away a little more after running the pool robot thing a few times. I'll grab some vitamin c and see if its copper. As for now, it almost looks like the surface of the moon down there with dark spots, rivers of white and dark.
    Here's another pic from this morning which is a better display of the issue.
    I'll be stopping by the pool store for a copper test on my way home today, but is it possible that the pool is a horrible mix of scaling, stained scaling, and copper staining?
    Mar 2011
    Sunny Central Florida
    91
    Mine is all mottled like that, I used to use copper algeacide a few years back. I don't have the big white stripe like on your stairs though. I think that my plaster (20+ years old) is jsut wearing out. I went thru a leak detection (was leaking .5" a day) and they found a cracked pipe under my deck. They did putty the **** out of the plaster first though, so it's very possible that plaster can leak....
    My guess on your white stripe is somebody dumped acid (like the slug method) right there.
    I have a little old scaling on my tile, and it's raised, like that white **** that gets on shells at the beach. I also have areas on my plaster that are pitted, I'm assuming due to age. Haven't seen the grey concrete yet, though, and I can't get a firm answer from anyone when you *have* to refinish gunite. It costs $4-6K, so I don't want to do it unless I *have* to.
    IG Plaster 20,000gal, attached spa w/ spillover, hayward C12002 cart filter, 1 1/2hp pump w/ polaris 360
    6/16/12 - PH 7.6, FC 6, CC 0, CYA 30, TA 80, Calcium 310
    Mar 2011
    91
    @Jasonlion Would acid lift the copper stains?
    Quote Originally Posted by danivdp
    Actually, the stairs picture has a reflection in it. I put it up to show the spots above the reflection.
    Bottom line: it's a mess, but we knew we needed a renovation.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    http://www.troublefreepool.com/pool-...metal%20stains
    Mar 2011
    91
    Quote Originally Posted by The Vern
    I see the trees now, LOL.
    Had the water checked at the pool store. No iron and only a minor ammount (<.2) on the copper. Should I do a AA treatment and use sequestrant?
