Thread: Solar heater
    Solar heater
    Well I'm of the opinion that pool water flowing through 3/4 inch black pipe on the black shingles on my roof should do a good job of heating the water as it flows through. Anyone had success doing this?
    17,500 gallon 16x32 doughboy Aboveground
    West Michigan
    Re: Solar heater
    Certainly you will gains some heat that way, but it won't be especially efficient. The commercial panels are inexpensive and more efficient than anything remotely simple to make.
    38,251
    Re: Solar heater
    It is all about square footage ... it takes a LOT of 3/4" pipe to get a lot of square footage. Typical recommendations are 50-100% of the surface area of the pool. For the same area, some of the pre-fab square panels seem to be about the same price.
    I just removed 2500 ft of 1" tubes from my roof (~210 sqft) and planning to put up 500 sqft of panels ... and I am in AZ
    Also note that it is VERY difficult to get all the water out of the irrigation pipe. This makes the plastic VERY soft if non-moving water is in it and the sun is out. And also results in freeze damage if you leave them out in the winter. I had this problem where we BARELY get below freezing. I was always fighting leaks.
    Re: Solar heater
    Thanks guys, I think i'll use the black pipe for watering the lawn.
    Cory
    West Michigan
