Thread: Prime Question
    Jul 2011
    North East
    135
    Prime Question
    Hey all.
    When the pump shuts off from its normal run cycle, the water in the basket area slowly drains and after several hours the water level is visibly low in the basket.
    Shouldn't the water stay at or near full in the basket? If thats the case I suspect a small leak in the new plumbing letting air into the plumbing.
    As a temporary remedy, I have the pump set to run on high for 2 minutes to refill the basket area, establish prime, and then kick over to low mode.
    Is my thinking correct on this or is it normal for water to leave the basket? I dont remember this happening on the previous pump.
    25,000 gallon Concrete/Plaster Pool
    Pentair WFDS-26 - Installed Spring 2012
    Pentair Quad DE 100 - Installed Spring 2012
    Pentair Kreepy Krauly 820 - In Service 05/26/2013
    K-2006 Test kit, Intermatic P1353me Digital Timer, Stenner 85MHP5
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Prime Question
    Does the basket fill completely with no bubbles when running? The suction from the pump can close a minor leak while running, which opens slightly when the pump shuts off.
    Jul 2011
    North East
    135
    Re: Prime Question
    Quote Originally Posted by JohnT
    Generally on high there are no bubbles; however on low there are some in the lid.
    38,343
    Re: Prime Question
    I too have bubbles when running on low, but the level does not go down when the pump turns off (which, now thinking about it is kind of odd )
    You have a leak somewhere that is allowing air into the system when the pump is off.
