Thread: Spa drains down when pump is off!
    Ok, my spa drains down pretty low when the pump shuts off. Ill try to post some pics. http://s1151.photobucket.com/albums/o639/cody7651/. Any ideas? Ive heard ortega valve is bad. Not sure how to replace that
    ajones02's Avatar
    Feb 2010
    Keller, Texas
    118
    Re: Spa drains down when pump is off!
    cody, i had the same issue when we first opened our pool and it turned out to be a back check valve. the PB came out and replaced it and that solved the issue.
    17,800 gallons, Pentair Clean and Clear 420 Cartridge Filter, Inground, Blue Granite Pebblesheen Interior, Pentair Intelliflo VS-3050 Pool and Spa pump, Pentair Whisperflo 2HP Water Feature pump, Pentair .75 HP Booster Pump for Pentair Legend pool cleaner, Pentair EasyTouch 8-function remote, Pentair IntelliChlor SWG.
    One of two valves has either gone bad or gotten debris stuck in it. The spa return should have a check/ortega valve that prevents water coming backwards through the return pipe when the pump is off. There is also a valve on the suction side that selects between pool and spa. If either of those valves fails to seal correctly the spa will drain down when the pump is off. Many valves can be opened up and debris removed and the seals inspected and replaced if needed. If your valves can not be opened up, you should replace them with ones that can be serviced.
    Did my link to the pics work? I think the ortega valve is in the far left of the first pic. It has a cap on the end of the pipe that looks like it screws off. Is it pretty simple to replace that?
    38,475
    See your other thread of similar topic for my suggestions.
    Although a quick search of the forums led to THIS POST with a link to a diagram for how to rebuild the Ortega.
    Thanks, Got it now
