Thread: Skimmer Outlets
    Skimmer Outlets
    I'm looking for a skimmer outlet that can replace the eyeball in a basic Intex 1.5 inch outlet. I would like the outlet to be around 45 degrees or so to give the surface a more circular flow. I presently have a 15' 42" pool modified with a 1500 gph skimmer pump and a 2500 gph for my SWG, Sand filter, and 50,000 BTU Heat Pump all hard-plumbed under ground. I added another inlet and outlet for the larger main pump using washer material obtained from hardware store with no leaks so far. (my first season).
    Above-Ground Pro Series 18'x48" Metal Frame - Approx 6,450 gallons
    Skimmer Filter System (cartridge): SFS1000 w/ F1500C Pump: 120watts/2.0amps/1500g.p.h
    Purchased & Installed: 6/7/12 (week of)
    Jul 2009
    Olney, MD
    218
    Re: Skimmer Outlets
    What is a skimmer outlet? If you are looking for a return fitting, then you can make whatever you want out of PVC from your local hardware store, just buy a 1.5 inch threaded connector and then any combo of pipe and elbows.
    20k gal, IG Vinyl, IntelliFlo VF Pump, 60 GPM sand filter, Jandy Aquapure Ei 35, 2 skimmers, one main drain, two returns, Dolphin Diagnostic cleaning robot, Taylor K-2006 test kit
    Re: Skimmer Outlets
    The outlet/return is from Intex. I hard plumbed all the way to (but not including) the return. The threads are metric and about 4" The eyeball piece is screwed onto it. I was just wondering if Intex sold other returns for this.
