Results 1 to 8 of 8
Thread: 2 lines in the skimmer?
    Molson's Avatar
    Apr 2008
    Midland, Ontario
    479
    I was filling the pool after removing the cover, enjoying a cold beer and decided to peek at the skimmer. While I was there, I removed the Gizmo (Why can't I invent such simple things and make a ton of cash?)
    I noticed that, other than the line teh gizmo was sealing, there was another typical plug in there. Should I remove that one too? I was under the impression that there should only be one line in there.
    40 x 16 IG Vinyl. Goldline SWG
    160 Sq Ft Roof mounted solar array
    2014 Hydropool Serenity 5000 Hot Tub
    The Pool School- A great place to start
    Jason's Pool calculator
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    No, the second line is for another type of plumbing where the main drain is piped via the skimmer.
    Molson's Avatar
    Apr 2008
    Midland, Ontario
    479
    Ok great. Thanks John. I think I am ready to fire the pump tonight. I am only missing one plug (I think) for the top of the sand filter, at the waste line, possibly an air release. The previous owner was very meticulous about keeping everything in one place, so I cannot see him losing this important piece, so I am thinking It doesn't get a plug.
    30,426
    Molson,
    Sometimes the psi guage goes on the top of the filter and is frequently removed for winterizing.
    Molson's Avatar
    Apr 2008
    Midland, Ontario
    479
    The PSI gauge was removed and placed back in its proper location. This plug area is approx 1 inch in size, with a rubber gasket or two inside. It appears to be fairly large threading.
    New Brunswick Canada
    819
    Quick Question
    A friend of mine has his main drain plumbed from the bottom of his skimmer, how does one go about clearing all the water from this when winterizing...we couldnt figure out anything due to water always coming in the Main Drain?
    Rik
    You can get a special gizzmo that has a tire valve stem which can be pressurized with a bicycle pump or air compressor to keep the water level in the main drain below the frost line. You pump it up till you see air bubbles coming from the main drain.
    Molson's Avatar
    Apr 2008
    Midland, Ontario
    479
    Quick follow up. Turns out the missing "plug" was the sight glass bottle. I wondered why he had a little bottle in the basket.
    Everything is on and working good. Seems the Baracuda isn't working as it should, but I'll figure it out. I have a leak around the filter top (band) and also where there was a patch applied at the pressure gauge, needs more goop. Running a constant 20 PSI from startup. Clear, but cold pool!
