Thread: Intex Sand Filter and saltwater system
    Pysiek's Avatar
    Apr 2012
    Frankfort , Illinois
    419
    Hey guys
    I'm not really experienced with pool chemicals. So my question is. Since I have the Intex sand filter with saltwater system installed can you guys let me know what should be mine weekly check up? What should I worry about the most. Right now I know the pH is to high but I will take care of that tonight.
    30'x54" Quest Above Ground Round Pool , About 21,000 Gallons , Hayward Perflex EC50 D.E. Filter System 1.5HP Power-Flo Pump , TF-100 Test Kit , Two Hayward Main Drains on the Bottom , Hayward CL200 In-Line Above-Ground Chlorinator.
    77"x77"x21.5" Hot Tub
    30,408
    Re: Intex Sand Filter and saltwater system
    Everything begins with test results. Tell us your latest test results and we can help you get where you want to be.
    Pysiek's Avatar
    Apr 2012
    419
    Oh boy. I will need to redo the test again then. I'm using the test strips that came with my Intex saltwater system. And the pH "square" is dark pink so I assume the pH is to high since the pink color is not on the chart.
    What is the best chemical testing kit for the pool? Do you recommend any?
    22,543
    I recommend the TF-100 test kit from tftestkits. I also recommend the Speedstir if you can swing it. You won't regret getting it. And since you have a swcg I also recommend you get a bottle of salt test strips.
