Thread: FC, CC and CYA at 0; added 68% Cal Hypo; FC 0.2 CC 3.0!
    davidm's Avatar
    Aug 2011
    Stratford, CT
    3
    Here's where I was after opening, adding pH increaser and baking soda:
    pH 7.5
    TA 130
    CYA <30, probably 0
    FC 0
    CC 0
    Then I added three lbs of 68% cal hypo. I tested after 1hr and now:
    FC 0.2
    CC 3.0
    I wasn't expecting the CC to spike so I just want to make sure I make the right next step. I added three more lbs of cal hypo and put two tri-chlor pucks in the floater. I plan on getting some CYA tomorrow to begin the process of raising that.
    Background: 17x35 in ground with a sand filter and vinyl liner. I have a safety cover so I am used to dirty looking water when opening. This is in CT, where is hasn't been very warm so far and I just opened this past weekend. I purchased a K-2006 kit last year based on the recommendation form this site and had great results with it. This is my first year opening on my own.
    I netted out leaves and ran my robotic vacuum a few times. There was still some sticky muck on the sloped and flat parts of the liner which would not vacuum out so I scrubbed it loose with a squeegee brush. Now the water is dark and murky with about 4' of visibility because I stirred up the loose organics while cleaning.
    Thanks in advance for your help.
    toadlife's Avatar
    May 2009
    Lemoore, CA
    57
    Re: FC, CC and CYA at 0; added 68% Cal Hypo; FC 0.2 CC 3.0!
    I would let the muck settle back to the bottom and then vacuum it out of the pool (preferably to waste) before bothering with chlorine. The muck is just going to continue to eat through your chlorine as you have already seen.
    21,000 Gallon IG Plaster with Spillover Spa (Built in 1978) | 48 sq/ft Hayward DE Filter | 3.0 HP Pentair Variable Speed Pump | Hayward H250FDN Heater| 8 Gallon Liquidator | Taylor K-2005 | Taylor FAS-DPD Chlorine Test | Taylor "SpeedStir"
    toadlife's Avatar
    May 2009
    Lemoore, CA
    57
    Oh, and welcome to TFP!
    davidm's Avatar
    Aug 2011
    Stratford, CT
    3
    Quote Originally Posted by toadlife
    This makes sense. It settled pretty well over night so this morning I vacuumed to waste and took a lot of brown stuff out of the pool. I dropped in the robot to mop up. I'll let it go a while and see if it looks like I should vacuum again or go back to chlorine. Thanks for the help.
    Butterfly's Avatar
    South Carolina
    10,045
    Welcome to the forum
    What is the CH level?
    You should be using bleach/liquid chlorine to shock. Here's a great article:
    turning-your-green-swamp-back-into-a-sparkling-oasis-t4147.html
    You're done SLAMing when:
    davidm's Avatar
    Aug 2011
    Stratford, CT
    3
    CH is 200
    The pool is starting to look good. Shock has been working for about five hours now. FC is 10, CC is 0.
