Thread: pump not keeping prime
    I have a 16000 gal fiberglass pool with sand filter, about 10 years old. I used to be able to use a timer for turning the pump on and off but the pump needs to be primed manually now. It has some air in the basket before the pump while running, but no air in the return lines. Suggestions?
    Re: pump not keeping prime
    check the gasket on the basket cover,, pump drain plugs,,, lots of good people on here that have mountains of knowledge,, they'll be along shortly...
    21000 Gallons I/G,,Vinyl,, 1.5 H.P. Hayward Pump,, Hayward Sand Filter S244T.. Liquidator.
    22,543
    You have a suction side leak. Joel gave you good advice. Check those and if that's not it, run water from a hose over the suction side plumbing and pump basket.
    from looking at my specific pump, it takes a 1/4" drain plug. My local pool store can get me a hayward 1/4" plug... that's not my pump manufacturer. Is it likely to work (is a drain plug a fairly universally interchangable part)?
    22,543
    They're ¼" NPT so they're universal.
