Thread: Is my math correct?
    Gulf Coast, AL
    61
    Is my math correct?
    If the pool is approx 16'x32' grecian and the level rises 1"...
    That one inch of water adds:
    16x32x.083 = ~ 42.5 cu feet x 7.48 gallons in 1 cu foot = ~ 318 gallons
    Aside from the pool not being exactly rectangular, is my math approximately correct?
    Thanks.
    16x32 Grecian, vinyl liner, IG, 19000 gal.
    1.5 h.p. Hayward Super Pump 2 speed. Hayward S244T sand filter
    Circupool RJ45 SWG, TF100
    mas985's Avatar
    Pleasanton, CA
    11,741
    Re: Is my math correct?
    Correct!
    Mark
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    That is what I get too. When you say it isn't completly rectangular, do you mean the corners are "cut". I shouldn't make much difference unless this is big "cut"/chamfer.
    Gulf Coast, AL
    61
    thanks.
    yeah, cut just a small amount like a typical grecian style pool.
